fully functional keyboard with Debian/Mobian
I had a fully functional keyboard under Arch/Monjaro w/
linux-image-5.17-sunxi64 using Megi's tutorial, but not having any luck w/
Megi's Debian/Mobian tut using the userland driver and vmlinuz-6.1-sunx64.
The userland driver doesn't seem to do anything, and loading the i2c-dev
module kills the native keyboard support. 'ppkb-i2c-inputd.service' shows up
in '>systemctl status' as enabled, but fails cause it 'can't find /dev/i2c-2
device', wh/ looks like a clue, but I read that those are loaded at boot time
and manually creating one doesn't seem like the solution.
I've also tried 'https://wiki.mobian.org/ppaccessories'.
I read that a fully functional keyboard w/ Debian/Mobian has been achieved
(year+ old reports and maybe a different kernel), yet it eludes me.
Soliciting suggestions/clues.
(02-09-2023, 07:07 AM)wigan Wrote: I had a fully functional keyboard under Arch/Monjaro w/
Update:
Referring to 'https://wiki.mobian.org/ppaccessories' above, the Automatic
Settings at the top didn't do anything, but adding 'export
XKB_DEFAULT_MODEL=ppkb' to ~/.profile (in the Symbol Keys section toward the
bottom) activated the top row symbols.  You'll need to go into 'settings >
keyboard > Alternative Character Key' and choose a key to use w/ numbers 1-10
to bring them up (the 'L3 key'?).
And disable the virtual keyboard in...
  Settings > Accessibility > Screen keyboard
  This doesn't stick between boots, but it's not much trouble, and it saves
  you from having to remember to reactivate it before removing the fon from
  the keyboard and not have a way to input.
Any clues on how to access the console??
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 3,842 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,288 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,067 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 23,928 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,626 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 19,855 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,517 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,595 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,150 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 21,284 06-29-2024, 04:09 AM
