Most recent Mobian image or installer image known to work?
(02-07-2023, 08:35 AM)Gumur Wrote: And the 20230205 is also OK.
It's ok as long as you don't upgrade. In my case, I'm stuck with a black screen.
Sorry, I did an upgrade today,and works as expected.
Have you rebooted at least once? For sure, yesterday, I wasn't alone to have to disable greetd and to reenable phosh to make it work.
I used installer...20230212 and it does decryption ok, but from then on stuck with a grey screen.
If I use tow boot to mount to laptop I get `part /media/user/boot` and `/media/user/root` mounts, the root I have to supply crypt password.
If one looks at the emmc with cfdisk there are 3 parts to it:
Device Boot Start End Sectors Size Id Type
>> Free space 2048 16383 14336 7M
/dev/sdb1 * 16384 999423 983040 480M 83 Linux
/dev/sdb2 999424 61071359 60071936 28.6G 83 Linux
It appears the root partiion is not expanded but encrypted part is 31G, i.e expanded
The free space, if highlighted reports a UUID, of type ext4, label of boot and mounted at /media/user/boot
Is this a quirk of cfdisk or is the table of eMMC corrupted in that it is remembering boot partition of previous install [ it crashed after an upgrade late last year ].
I'm downloading the install....20230226 tonight to see if that is the same.
  Mobian image for the PinePhone Korfou 2 637 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 57,159 12-24-2025, 12:11 AM
  Alarm clock doesn’t work Captain1ndustry 14 27,166 12-23-2025, 12:12 AM
  cryptocurrency on mobian/pinephone biketool 35 67,372 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 33,282 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,708 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 315,764 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,425 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,270 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,877 05-06-2025, 02:19 AM
