No audio on calls after updating today
(12-12-2022, 08:27 PM)Zebulon Walton Wrote:
(12-12-2022, 07:04 PM)BaronAlbatross Wrote: If you have the time, could you spell out your process please? I have an important call tomorrow and I have no time at all to get it wrong and make a bigger mess!
If you're talking about going back to pulseaudio after having moved to pipewire, it was basically a matter of reversing what was done - disable pipewire and re-enable pulseaudio. I had to play around with it a bit but it came down to the following commands run as the normal mobian user:
# Disable pipewire systemctl --user stop pipewire pipewire.socket pipewire-pulse systemctl --user disable pipewire pipewire.socket pipewire-pulse systemctl --user mask pipewire pipewire.socket pipewire-pulse # Enable pulseaudio systemctl --user unmask pulseaudio pulseaudio.socket systemctl --user enable pulseaudio pulseaudio.socket systemctl --user start pulseaudio pulseaudio.socket
It's a good idea to keep a "known to work" SD card on hand just in case. Don't update it once it's you have it in a workable state. Having that has saved my bacon on a few occasions.
Thank you so much! I think I will make a backup after this, it should have been common sense!
  Mobian, Suspend, and Audio Playback biketool 0 2,918 12-11-2024, 12:56 AM
  Calls 4G not working oliwierzgorniak 2 5,687 08-06-2024, 02:20 PM
Last Post: baptx
  Audio output switching anomalies treebeard 1 3,318 06-10-2024, 06:37 AM
Last Post: anonymous
  Bluetooth audio revisited 3x5co 1 3,602 01-10-2023, 05:51 PM
  Ringtones and Audio Modes biketool 0 2,372 09-05-2022, 10:42 AM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 2,804 07-17-2022, 10:34 AM
Last Post: 3x5co
  Problem updating gilwood 5 7,711 06-09-2022, 08:27 AM
Last Post: gilwood
  Chrony interrupts calls. jhasler 0 2,249 04-18-2022, 08:48 PM
Last Post: jhasler
  Bluetooth audio support? Zebulon Walton 5 8,835 02-28-2022, 08:59 AM
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 6,664 02-18-2022, 08:54 AM
Last Post: battlegarden
