PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID
On PostmarketOS v22.06 Plasma Mobile on PinePhone Pro, and when I reboot the phone, and then log in, the PinePhone Pro does not connect to a saved WiFi SSID.
I have to manually go to WiFi settings, and press on the saved network, and PinePhone Pro then will connect.
Where can I edit to change this behavior, and have PostmarketOS device connect to the WiFi automatically?
By the way, I am very glad and thankful that there is a FUNCTIONING PHONE OS out of the box, like PostmarketOS; It was an exodus from other OS distros, and a month of troubleshooting with Manjaro, to have the PinePhone Pro functioning like a phone. Thank you!
I agree that Postmarket is a good call. It was the first plasma version that actually ran right. At present I have Arch plasma and phosh on each of my phones. They also work well although Arch plasma has some work to do. Yet not bad at all.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
I tested the PinePhone Pro one month ago and can confirm the same issue.
I have now switched to Librem5 with Postmarket v23.12. Here, any Wifi connection breaks after several minutes and it asks me for the password on any reconnect. Somehow unusable Undecided
This is a well known bug, and this comment in the bug-thread explains what you can do to solve this temporarily.
There's hope the bug may be fixed once postmarketOS provides Plasma Mobile images with systemd.
Because I am lazy and kept forgetting about this, I've since a copy of the following as a file called network-fix.sh on all my Plasma Mobile devices:
#!/bin/ash
# Path to the directory with .nmconnection files
DIR="/etc/NetworkManager/system-connections/"
# Loop through each .nmconnection file in the directory
for FILE in "$DIR"*.nmconnection; do
    # Check if the file contains a "permissions=" line
    if grep -q "^permissions=" "$FILE"; then
        # Replace the entire permissions line with just "permissions="
        sed -i "s/^permissions=.*/permissions=/" "$FILE"
        echo "Updated $FILE"
    else
        echo "No permissions line found in $FILE"
    fi
done
Just put this in a file called network-fix.sh on your phone, mark it as executable (chmod +x network-fix.sh) and run it (./network-fix.sh) whenever you have connected to a new network you automatically want to reconnect to.
  Freezing and force rebooting on PinePhone HHawks 4 3,614 05-02-2025, 09:04 AM
Last Post: HHawks
  Gnome mobile user641 1 3,356 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 6,161 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,002 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 11,335 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 2,818 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  installed postmarketos v23.06 no audio samlo 1 3,744 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 3,407 07-01-2023, 08:16 AM
Last Post: AndyM
Question Always Use Mobile Data DingDangDoong 4 5,930 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  VPN for PostmarketOS publiclewdness 1 4,527 03-11-2023, 04:35 PM
