GPS position
Hi , my pinephone pro has the SIM sock broken . Can I still get a gps position from Manjaro plasma in my SD card?
regards
Emilio
I don't understand the question Smile
FYI, I flashed Manjaro Phosh (daily build) to my PinePhone Pro eMMC because I wanted to play with the keyboard, and to my surprise and delite, GPS works great.
***   Don't be a minion in the (i)droid army   ***
(06-21-2022, 11:58 PM)Emilio Wrote: Hi , my pinephone pro has the SIM sock broken . Can I still get a gps position from Manjaro plasma in my SD card?
regards
Emilio
GPS works independently of having a SIM card inserted or not, so yes. Make sure the phone has a GPS fix, though -> https://wiki.pine64.org/wiki/PinePhone#GPS_/_GNSS
regards
Emilio
That's true at the hardware level, but not if you're using ModemManager as most distros do. The ModemManager interface will only allow GPS to be enabled if there's a SIM present. You need to stop ModemManager then use something else to enable the GPS - I used picocom to send AT commands.
https://gitlab.freedesktop.org/mobile-br...issues/183
Users browsing this thread:
