nextcloud setup
I could not find this in the wiki. I am to set up nextcloud. I go to settings / account / add nextcloud account.
When I enter my url, I get a
"unable to connect to nextcloud at the given server url. please check the server url"
Which kind of address should it be exactly?
Say, I can log in on https://www.example.com/myfolder/index.php/login then what should be the address?
(10-23-2022, 01:35 PM)mruser1 Wrote: I could not find this in the wiki. I am to set up nextcloud. I go to settings / account / add nextcloud account.
happens to me if I try PostmarketOS Plasma Mobile. With Manjaro Plasma Mobile it works quite well. Bur for a Calendar you'd better install Kalendar which brings it's own NextCloud connection.
For me it is just the default address without anything fancy - same as you type to browser.
Like
https://mynextcloud.com
And it works (Manjaro Phosh, PMOS, Mobian, Arch all tested Smile )
  CardDAV / Nextcloud sync broken Uturn 0 3,415 06-15-2023, 12:41 AM
Last Post: Uturn
  .CSV Without Nextcloud food 5 6,984 01-24-2023, 03:51 PM
Last Post: alaraajavamma
  how to connect calindori to nextcloud? Uturn 2 5,279 06-26-2022, 02:09 AM
Last Post: wibble
  "Emergency" terminal on pinephone (with default setup) altulke 5 7,470 05-03-2022, 12:42 PM
Last Post: altulke
  Setup/settings lost on reset/reboot GrapeJuice 0 2,561 02-10-2022, 05:40 AM
Last Post: GrapeJuice
  Nextcloud folder (WebDAV) not showing up in Portfolio PinePhoneUser 1 3,388 01-13-2022, 08:31 AM
Last Post: Uturn
  nextcloud contacts are duplicating Uturn 1 4,702 10-24-2021, 01:35 AM
Last Post: user641
  Plasma Mobile, Nextcloud account Uturn 1 4,025 03-05-2021, 09:14 AM
Last Post: Veraendert
