Mobian external display woes
I replaced the faulty motherboard on my pinephone with a new one, and it seems to be running Mobian fine...
I got a USB hub, with 3 USB 3.0 ports and an HDMI port, so I could connect a keyboard, mouse and external display to the phone, using it as a computer when at my desk.
But now whenever I start using it, the external display will blank almost every second.. sometimes it will go into sleep mode. Sometimes it's so bad that I have to disconnect the HDMI to get it back. the USB Hub is powered externally.
The external
Does this happen to anyone else? Does anyone have a clue why this might be happening?
It makes it really frustrating to use.
ps - it seems like every time it writes anything to the external display, it blanks until its done. And for some reason sometimes it just goes into power-saving.
(10-21-2022, 04:39 PM)Hiraghm Wrote: I replaced the faulty motherboard on my pinephone with a new one, and it seems to be running Mobian fine...
The external
Are you using mobile broadband at the same time?
This exact thing happens when you are using the mobile broadband at certain frequency (it sends a "pulse" that interference the hdmi connection and the screen flashes like crazy). For me that frequency is 4G but your carrier might use different frequency.
It might not happen if you use some offline app like gedit and there is minimal data transfer but if you try to load website or send email it is most of the time useless.
The external
Not all docks are compatible. Try using a Pine dock and see if the issue clears up. I also have another brand of dock and it doesn't work that well. The display is intermittenet at best.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
thanks for the info. when they get one in stock, I'll get one.
The external
The external
Thanks for the info. Of course I had my 4G on at the time, but I was connected to my network via wifi, I wasn't using it... I'll try it again with 4G turned off and see what happens.
That was the problem. I turned off 4G and it stopped doing that.
So I'll pick up a convergence as soon as I can.
I can confirm that. I bought a:
"USB C Hub Type C Hub Adapter, Ablewe 5 in 1 Aluminum USB C to HDMI 4K Adapter with 3 USB 3.0 Ports,87W Power Deliver(PD) for MacBook Pro 2017/2018, XPS and More USB C Devices"
from Amazon. I get no HDMI output at all with my PinePhone.
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12)
PineTab2 Arch Danctnix 6.4.2
  Mobian MMS/SMS text problem bcnaz 16 35,014 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 974 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 61,068 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,276 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,896 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 325,641 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,598 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,525 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,203 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,964 04-29-2025, 02:10 PM
Last Post: mdk
