Latest Reliable Mobian Build Confirmation Thread
Hello everyone. I need to do a fresh reinstall of Mobian. Rather than ask just for my own benefit now, I thought it might be useful to have an ongoing thread where we can confirm the latest reliable builds. The Mobian Team continues to make great progress but sometimes updates go sideways for reasons no one could have predicted. Thank you in advance to everyone for your contributions.
Alright.. so this is like the sixth time I've asked across various threads. What is the most recent build of Mobian where 4G, txting, calls & the camera works properly? I gave up on waiting for an anyone to help me last night and installed Manjaro. I hated it. So please can anyone, anyone at all, tell me which build should I be using for a fresh install???
I tried version for PPP from 21.8 and it was working, except call in audio (resolved by update), but after current updates from last week audio and modem seems not working properly. I tried installers from 18.9 (wasnt working at all) and 25.9. (installation finished but phone couldnt boot system). Didnt try earlyer versions.
(09-26-2022, 10:33 AM)mollag Wrote: I tried version for PPP from 21.8 and it was working, except call in audio (resolved by update), but after current updates from last week audio and modem seems not working properly. I tried installers from 18.9 (wasnt working at all) and 25.9. (installation finished but phone couldnt boot system). Didnt try earlyer versions.
Thank you. The last time I remember it woking properly was back in June I think. They had resolved the 4G issue, texts didn't need to be constantly flushed in terminal to be received and the camera seemed fine. Does anyone remember which build fixed the 4G issue? Installing that one is the best I can think of now.
Which image works best for _you_ right out of the box is impossible for anyone else to guess.  I assume you're going to do a dist-upgrade at some point so it doesn't matter so much where you begin - you'll end up at the same place.  4G, calls in general, and SMS have worked fine for me for about a year.
From when I originally installed Mobian in autumn 2021, it was often having that problem where I'd have to go into terminal and manually delete txt msgs that were stuck and wouldn't deliver. This past spring, Mobian had to be reinstalled due to a crash and after that my txts worked fine but 4G didn't work. You can find a thread with people discussing that problem if you look back a couple pages. Then after a couple months 4G got fixed in an update but a couple months after that texts started having the same problem as before. A few weeks ago the modem would keep crashing and calls would drop so I tried updating then the internet wouldn't work. I tried a solution in the forums but that didn't correct the internet issue so I decided it would be easiest to just do a fresh reinstall. I'd just like to know which build is safe to use.
  Printing from Mobian johnd 3 5,134 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,095 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,116 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,843 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,348 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,624 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,614 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,304 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,571 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,307 05-06-2025, 02:19 AM
