Time is wrong after reboots stucked at 27th august
After performing a reboot my date is wrong stucked at august 27th, I must fixed it every time using 'date --set'
I started having this issue today.
That will happen if the phone cannot obtain the current date and time from the internet. In order to preserve date and time under those conditions you need to go into Settings and turn off automatic date setting. (That's what I do since I do not use mobile data and have the wifi turned off most of the time.)
(09-08-2022, 11:18 AM)Zebulon Walton Wrote: That will happen if the phone cannot obtain the current date and time from the internet. In order to preserve date and time under those conditions you need to go into Settings and turn off automatic date setting. (That's what I do since I do not use mobile data and have the wifi turned off most of the time.)
I see, but I always have wifi and 4g internet, that's why I found it strange.
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 8,054 04-26-2024, 04:56 PM
Last Post: zetabeta
  [solved] Black screen at boot time mdk 0 2,795 01-13-2023, 03:33 AM
Last Post: mdk
  spontaneous reboots in jumpdrive mode flynx 0 2,248 08-23-2022, 03:48 PM
Last Post: flynx
  Date & Time-setting app is a very poor design treebeard 6 8,556 07-27-2022, 06:35 AM
  Header bar date/time vs time-only option Korac 2 4,446 01-17-2022, 10:02 AM
Last Post: Korac
  22 July 2116 -- wrong Date & Time Anna 7 12,480 07-30-2021, 07:29 PM
Last Post: bcnaz
  Axolotl on Mobian. What am I doing wrong? quixote 3 6,462 05-11-2021, 06:09 PM
Last Post: quixote
  Wrong location / place by GPS - Location Services - GNSS - Maps Anna 17 25,116 03-22-2021, 12:42 PM
Last Post: Maus
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 7,603 01-01-2021, 08:03 PM
Last Post: calinb
  "Oh no, Something has gone wrong, Logout" pajux 11 21,874 11-12-2020, 05:22 PM
Last Post: pajux
