Enable Ethernet Rooted 5.1.1 (05/05)
Brick
Preface: Running A64+ 2GB board with a 16GB Sandisk class 10 card running Android Rooted 5.1.1 2016/05/05 release found here.
How does one enable ethernet within android? I can get the wifi working just fine however I can't seem to find any options to enable/configure ethernet within the OS.
The only thing close I can find is under data usage you can track data over ethernet, however every time I click it the settings panel crashes.
I've tried using both in 1Gbps and 100mbps mode (by using a switch, verified to be working at 100mbps with other hardware) and the Ethernet just won't work.
Anyone had any luck getting the ethernet working within android on this board?
(06-02-2016, 01:27 PM)Rumen Wrote: Preface: Running A64+ 2GB board with a 16GB Sandisk class 10 card running Android Rooted 5.1.1 2016/05/05 release found here.
I had no issues. I have the 1GB board version and wrote my android-rooted-ver5.1.1-20160505-pine64-8GB.img with dd.
I have an old cheap netgear switch GS108
Here is my settings... wifi is off currently.
root@tulip-chiphd:/data # ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes:   10baseT/Half 10baseT/Full
                       100baseT/Half 100baseT/Full
                       1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes:  10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Link detected: yes
Jim
It turned out to be an issue the DHCP service running on my router, ethernet is working fine now.
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 7,309 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 6,643 12-07-2017, 05:09 AM
Last Post: daniele
  No Ethernet on Andriod rvalecruz 5 14,020 05-05-2017, 01:59 AM
Last Post: Quezbeme
  My Hacky ethernet fix anarchyuk 21 45,876 11-20-2016, 12:01 PM
Last Post: waldo
  Lost Ethernet hatman28 13 27,839 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 36,096 10-29-2016, 04:31 AM
Last Post: joe
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 10,170 09-22-2016, 03:56 PM
Last Post: edszr.co
Question Rooted Android 5.1.1 - Phone, Dialler & SMS Green Cherry 2 6,728 09-10-2016, 08:14 PM
Last Post: dkryder
  Can I rotate Screen Android 5.1.1 for LCD (not rooted) steveslim 4 11,708 09-04-2016, 09:35 PM
Last Post: steveslim
  Android Ethernet Problem a5467021 11 26,657 08-01-2016, 07:41 PM
Last Post: a5467021
