Disable on screen keyboard permanently.
(02-15-2022, 11:48 AM)Zebulon Walton Wrote:
(02-15-2022, 08:05 AM)wibble Wrote: Based on the script on the wiki page I guess something like this should work as the basis for a script which you could then add a .desktop file for:
if [ $(gsettings get org.gnome.desktop.a11y.applications screen-keyboard-enabled) = "true" ]; then  gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled false; else  gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled true; fi
Thanks, that works great!
What I did was use that in a shell script ~/bin/keybd, that displays the result before exiting:
#!/bin/bash
echo ""
echo ""
echo ""
echo =====================================================""
echo "Toggling on-screen keyboard..."
echo "Keyboard is now: $(gsettings get org.gnome.desktop.a11y.applications screen-keyboard-enabled)"
sleep 2
I installed xterm since I found that unlike King's Cross the xterm window closes completely after it exits (no need to swipe up).
sudo apt install xterm
Then I created the desktop file in ~/.local/share/applications/keybd_toggle.desktop:
[Desktop Entry]
Name=04 Toggle Keybd
Type=Application
Exec=/usr/bin/xterm -fg white -bg black -e /home/mobian/bin/keybd
Categories=Utility;
X-Purism-FormFactor=Workstation;Mobile;
This makes for a very quick way to toggle the onscreen keyboard. (The reason for the number "04" in the name is to put this near the top of the screen. I have my most frequently used icons named that way, currently prefixed 00 through 04.)
Thanks for showing your work. I used it as a basis for my own and incorporated both turning the software keyboard off and changing the charging limits for use with the keyboard case.
echo -n 1500000 | sudo tee /sys/class/power_supply/axp20x-usb/input_current_limit
A side note, you can close force close kgx with "kill $PPID" at the end of the script.
Wish I could get around having to enter my password for the sudo part though
(06-08-2022, 08:25 PM)SwordfishII Wrote: echo -n 1500000 | sudo tee /sys/class/power_supply/axp20x-usb/input_current_limit
Check the NOPASSWD option in /etc/sudoers - you can use it to allow specific commands to be run without requiring the password. Something like:
your_user_name ALL=(ALL) NOPASSWD:/usr/bin/tee /sys/class/power_supply/axp20x-usb/input_current_limit,some_other_command_you_want
That is exactly what I did the other day! It was quite handy
  Disable vibrations 3x5co 9 12,985 01-03-2026, 12:26 PM
Last Post: baptx
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 295 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 6,725 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 694 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,141 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,349 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 4,612 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 33,217 01-13-2025, 01:37 AM
  how to disable ipv6 at kernel level with towboot? vusra 3 3,627 10-04-2024, 04:23 AM
Last Post: vusra
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 8,289 08-05-2024, 06:12 AM
Last Post: baptx
