Vibration motor buzzes uncontrollably with call waiting
Today I had was on a call using the Pinephone and a second call came in (a scam/spam call). What happened is the call I was on was disconnected and the vibration motor came on - and stayed on, would not turn off. Even when the legit guy called back and I picked up the vibration motor just kept going. It did not shut off until the phone was rebooted.
So... when this happens is there some way the vibration can be turned off short of rebooting the phone? (I'm using the "002" factory firmware if that makes a difference.)
sudo killall feedbackd
works for me, to the point I aliased it as 'krt' (kill ring tones) in my .bashrc
Cool, thanks!
What I'd really like is to disable call waiting entirely so a second incoming call goes right to voicemail. However the firmware version currently running in my modem does not accept the commands (just reports an error) and apparently it's only possible to disable call waiting that way for 2G and 3G connections anyway. (Those have been discontinued in my area, I'm using 4G.) That topic was covered here on the board in another thread:
https://forum.pine64.org/showthread.php?...#pid105645
Probably at some point gnome-calls will be updated to handle call waiting better but for now just being able to turn off the alert will do.
  activate vibration motor in bash script? vusra 0 946 07-18-2026, 03:47 AM
Last Post: vusra
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,684 12-01-2024, 07:54 PM
Last Post: dchang0
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,735 08-05-2024, 06:12 AM
Last Post: baptx
  Command to test vibration motor? Zebulon Walton 3 6,096 11-12-2023, 08:45 PM
Last Post: zetabeta
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 3,613 01-04-2023, 06:46 PM
Last Post: 3x5co
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 7,581 06-02-2022, 07:16 AM
Last Post: arkadione
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 8,425 03-01-2022, 10:06 AM
Last Post: bujiraso
  Calls : two rings and call cut and restore. Gribouille 0 2,252 01-14-2022, 07:40 AM
Last Post: Gribouille
  GDM3 Receiving call on login screen d-.-b 4 8,580 10-07-2021, 06:59 PM
Last Post: d-.-b
  Mobian Constant Vibration tumblingdog 4 8,196 07-10-2021, 02:40 AM
Last Post: aed
