Fix keyboard layout
I am using Manjaro plasma and I'm having some trouble getting the keyboard layout to work with the characters under the number row.
I have tried the suggestion on https://forum.pine64.org/showthread.php?tid=16507 (Step 8) as well as reading the doc at https://wiki.archlinux.org/title/X_keyboard_extension
When I create the layout and try to load it I get
# setxbmap -layout ppkb
WARNING: Running setxkbmap against an XWayland server
and they changes don't seem to work. Even if I for example override a number key with a different number.
Has anyone had any success in fixing this?
Somewhat working
Console:
Follow instructions at https://codeberg.org/HazardChem/PinePhon...h/main/tty
The file to edit is /etc/vconsole.conf. If keymaps is included in yout /etc/mkinitcpio.conf then it will work from initramfs (run mkinitcpio -P to refresh it)
caveat: Ctrl key is no longer working for me
Wayland/Plasma:
Update your /usr/share/xkb/* to the files in https://codeberg.org/HazardChem/PinePhon...h/main/xkb
I'm not sure the correct way to configure wayland/plasma to use the layout but I had success with creating
~/.config/kxkbrc
[Layout]
LayoutList=us
Model=ppkb
I tried several things but I think this is what got it to work in Plasma/Wayland.
If you don't want to change the files in /usr/share/xkb/ you can create them in your home directory, see:
https://xkbcommon.org/doc/current/md_doc...ation.html
Ideally we could select it using the 'System Settings' application, as it is on the desktop, but I'm not sure which packages are needed to get this to work.
  Battery meter slowly reducing under keyboard charger robocone 1 3,343 12-26-2022, 09:37 AM
Last Post: robocone
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 9,526 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Screen keyboard Japanese input issue Yst 1 2,987 04-30-2022, 09:13 PM
Last Post: TRS-80
  Keyboard Case Power Management Daemon estokes 11 13,708 04-19-2022, 07:41 AM
Last Post: PineFLOWn
  Howto Full disk encryption manjaro and detached header (with keyboard) robocone 0 4,103 03-09-2022, 06:53 AM
Last Post: robocone
  Keyboard stopped working -- big problem tckosvic 15 17,291 02-06-2022, 02:04 PM
Last Post: Emilio
