Cannot get my board to boot
(03-17-2022, 06:44 PM)deutschlmao Wrote: It was the microSD. I tried another one today and got it fixed
That's the usual culprit. A bad SD card or a badly written image on to it. I thought you may have already tried that before you posted your issue.
I found another possible culprit for "sd not booting correctly" problems - cr*p USB to Micro/SD card converters!
I have two of these - they are both coloured white, have a sd card slot in the side, plug directly into the USB port and are USB 2 based.
One of them is noname-branded and the other is branded "integral". I tried using different usb cards with both of these adapters and the pine64pro would not boot from any of the cards that these converters wrote to. I tried about 4 different types (sizes/brands) of microsd cards (via a microsd to sd card converter; these are I believe passive and have no electrical components inside they just expose the smaller microsd contacts to the larger sd card) and no joy.
I then tried one of the cards that would not boot with a different usb 3 microsd to usb converter (and one of better quality) and it worked first time.
I have no idea for sure but it seems like some of these cheapo adapters can't write to certian parts of the sd/microsd cards correctly. Prehaps it is because they were probably intended for use with window$ PCs?
Here's a picture btw of the microsd to sd card converter (working), one of the microsd cards(working) and the two converters which definately *don't* work...
ljones
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,856 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 30,276 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 225,621 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,140 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 4,522 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,839 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,764 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,100 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,609 09-06-2022, 10:32 AM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,576 07-19-2022, 10:48 PM
Last Post: hazz
