05-29-2016, 06:41 AM
So I'm a little embarrassed this has stumped me. I've never set up a mail server before, though and I'm having some trouble. I don't want a full mail server at this point, I just want to send outbound notifications to myself, so I'm not linking this to a valid domain name.
First, I installed postfix , since that seemed to be the consensus as the best option. And.... that's where I'm stumped. The mail command just hangs when I try to send a test message to my Gmail account, and I'm sure I need to set up some parameters in the /etc/postfix/main.cf config file but I'm struggling to figure it out what exactly.
I've looked at this, but I'm not really seeing an answer there. Also, I should add that it appears postfix is running OK:
I've also installed sendmail because it didn't appear to be installed, but I still get a "command not found" error when I try to use it from the command line. mail gives no such error, but just hangs and never sends the message.
I thought this would be easy! I'm sure I'm doing some simple dumb mistake, though. Any help would be very appreciated.
inetv@pine64pro:~$ sudo systemctl status postfix
postfix.service - LSB: Postfix Mail Transport Agent
Loaded: loaded (/etc/init.d/postfix)
Drop-In: /run/systemd/generator/postfix.service.d
└─50-postfix-$mail-transport-agent.conf
Active: active (running) since Sun 2016-05-29 11:41:07 UT
ago
Process: 1851 ExecStart=/etc/init.d/postfix start (code=ex
tus=0/SUCCESS)
CGroup: /system.slice/postfix.service
├─2092 /usr/lib/postfix/master
├─2093 pickup -l -t unix -u -c
└─2094 qmgr -l -t unix -u
ay 29 11:41:07 pine64pro postfix[1851]: Starting Postfix Ma
ay 29 11:41:07 pine64pro postfix/master[2092]: daemon start
ay 29 11:41:07 pine64pro systemd[1]: Started LSB: Postfix M
int: Some lines were ellipsized, use -l to show in full.
