Scripting Bluetooth Hotspot for Mobian
We already have almost everything we need here.
I want to get Bluetooth hotspot working on my Mobian/Pinephone, Bluetooth tethering a laptop or tablet while on the train, hotel, during a power outage, or at coffee is a basic daily driver phone requirement in my opinion.
I am sure the modern kernel has the required modules but I don't know what the interface name for bluetooth network interface for the pinephones bt driver; bnep0 is the interface used on this old N900 script.
I think this is an easy edit to the other network interfaces like USB already in the wiki unless iptables has changed much since the 2010s.
BT PAN tethering is by far the best and easiest way to tether to your phone's internet connection vs WiFi which wastes far more electricity per Mb transmitted for little benefit other than maybe easier sharing a wifi password with friends vs them having to pair with you on BT.  The security is provided by the bluetooth pairing process.
Below is the scripting to get full service, including DHCP, automatic Bluetooth PAN hotspot running on the Nokia N900, how much will work as is?.
install the iptables package:
apt-get install iptables
create the following 2 files:
/etc/udev/rules.d/98-bnep0.rules:
ACTION=="add", SUBSYSTEM=="net",  KERNEL=="bnep0", RUN+="/etc/udev/bluenet.sh"
ACTION=="remove", SUBSYSTEM=="net",  KERNEL=="bnep0", RUN+="/etc/udev/bluenet.sh"
/etc/udev/bluenet.sh:
#! /bin/sh
if [ $ACTION = "add" ]; then
    echo 1 > /proc/sys/net/ipv4/ip_forward
    iptables -t nat -A POSTROUTING ! -o lo -j MASQUERADE
    ifconfig bnep0 192.168.3.1
    ifconfig bnep0 up
    /usr/sbin/dnsmasq -I lo -z -a 192.168.3.1 -F 192.168.3.64,192.168.3.127 -x /var/run/dnsmasq.pid.bnep0
else
    iptables -t nat -D POSTROUTING ! -o lo -j MASQUERADE
    if [ -f /var/run/dnsmasq.pid.bnep0 ]; then
        DNSMASQ_PID=`cat /var/run/dnsmasq.pid.bnep0`
        rm -f /var/run/dnsmasq.pid.bnep0
        kill $DNSMASQ_PID
       fi
fi
then set /etc/udev/bluenet.sh as executible:
chmod +x /etc/udev/bluenet.sh
now whenever an authorised remote device makes a bluetooth pan (nap) connection iptables and dnsmasq are setup to allow that device access to the phones network. TODO: when no internet connection is active ask to set it up
The mobian wiki has instructions for USB, and LAN, WIfi hotspot is included but bluetooth PAN entry is not yet explained in the wiki.
https://wiki.mobian-project.org/doku.php...networking
I have moved beyond this post to working on the bluez and udev rules
(edit) and now I am trying to fix routing but I have PAN/NAP profile working and can pair and get an IP address just working to fix the bridging between the WAN/internet and BT LAN.
see here
https://forum.pine64.org/showthread.php?...#pid108330
  Mobian MMS/SMS text problem bcnaz 16 37,081 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,404 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,293 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,125 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,173 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 333,765 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,869 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,891 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,605 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,331 04-29-2025, 02:10 PM
Last Post: mdk
