LCD Pannel working... Touch screen NOT working?? Why
As the title suggests My Pine 7" LCD is working (showing graphics) but not responsive to touch at all. Im booting the LCD android 5.1 from the wiki.
The only thing I can think of, is look how sheet the ribbon cable plug was attached to the board from factory. I couldnt say If its the problem but Its suspicious.
 [Image: 13313604_1183537048365249_91336053_o.jpg]
(05-30-2016, 02:00 AM)Chopshop13 Wrote: As the title suggests My Pine 7" LCD is working (showing graphics) but not responsive to touch at all. Im booting the LCD android 5.1 from the wiki.
The DSI connector just for LCD panel and your connection looks correct. For touch screen to work, you need to connect the thin flex cable to the TP port.
(05-30-2016, 02:50 PM)tllim Wrote: The DSI connector just for LCD panel and your connection looks correct. For touch screen to work, you need to connect the thin flex cable to the TP port.
Ahhh I seeee. Thanks.
Thank you so much ChopShop13 for asking the question and to tllim for answering! I had the same issue! Now I'm up and running with both HDMI and the LCD panel (on separate cards) (and off to searching for the next issue)!
Exclamation LCD 7" Pine64 own not working with pine64 A64 board HL3D 0 10,809 01-27-2025, 10:51 AM
Last Post: HL3D
  Is there a screen for the Rockchip RK3399 that works with FreeBSD out of the box ? ziomario 0 1,732 11-10-2024, 02:06 AM
Last Post: ziomario
  7 inch LCD touch panel is upside down? joshpl 2 5,263 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 5,487 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 58,371 07-21-2017, 07:41 AM
Last Post: apple4ever
  I2C Touch Panel mbt28 0 3,604 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD screen brightness/contrast Learnincurve 10 22,534 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 10,714 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 32,843 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 16,267 11-27-2016, 10:26 PM
Last Post: michaelquezon
