SIM or SIM Adapter stuck, potential fix.
Hello
Alot of people has had issues with the SIM adapter. It's very hard to get it in and the SIM easily slips out. If the SIM adapter goes in alone, it will be stuck in the pins and seemingly impossible to get out. I had this issue and i was afraid i broke my new phone, until I found a solution that worked for me which seemingly isn't mentioned anywhere on the forum. If anyone from Pine64 sees this, i would recommend changing the SIM installation method in the PinePhone Pro or in the next hardware revision.
Kind Regards
  Wifi no scan results - Bluetooth adapter not available emsyr 1 3,971 08-29-2022, 02:46 PM
Last Post: emsyr
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,319 03-08-2022, 12:25 PM
Last Post: jopple
  Seeing no WWAN adapter or No SIM jcun4128 2 5,223 03-04-2022, 02:23 AM
Last Post: jcun4128
Lightbulb SIM adapter suggestion ganaxe 0 2,469 05-14-2021, 02:12 PM
Last Post: ganaxe
  Will 5GHz USB wifi adapter work? Zebulon Walton 1 5,815 12-01-2020, 06:17 PM
Last Post: nas
  Nano sim to micro sim adapter not working Qiangong2 5 12,378 06-09-2020, 02:22 PM
Last Post: bcnaz
