Why no AndroidTV Image
I bought the Pine 64 with 2GB, the remote, and the keyboard. I expected the company to provide a REAL AndroidTV image for us to use. They made all this discussion about 4K.  Why is there no real AndroidTV image?
Is this hard?
http://forum.pine64.org/showthread.php?tid=1063
its in the sticky at the top of this forum, fyi its a work in progress
(05-25-2016, 05:12 PM)Raslin777@gmail.com Wrote: http://forum.pine64.org/showthread.php?tid=1063
That is not a 'real' android TV img. However, it does fill a gap in the current image line-up, and offers an androidTV-LIKE experience. I know of another media-focused project in the works - should see the light of day in the coming weeks. Its still very early days Wink
That is my reason for asking. Why did they offer a REMOTE and KEYBOARD if not REAL AndroidTV image?
Is this hard?  Glad to see some are trying to bridge the gap.  My device got delivered yesterday, but I am out of town.
I will be working on this when when I get mine delivered. Should be fun. This is my primary reason for getting the device too so I will be spending alot of time on this.
You asked if it's hard/I'm sure it's not easy. Everything takes time testing tweaks alot of the time the app/system check sigs, build props, root checks, require libs and dependencies that may not be in the aosp build. Often requires sometime dex debugging/lib debugging/logcat.
It all depends on how secure google wanted to make. the platform.
Also Luke, just wanted to say its awesome you got a IRC channel up. Ty. Ill be using it after I can get to some testing.
(05-26-2016, 10:14 AM)Raslin777@gmail.com Wrote: I will be working on this when when I get mine delivered. Should be fun. This is my primary reason for getting the device too so I will be spending alot of time on this.
Correct. I am not a dev, so I do not speak from experience, but from seeing Lenny and others work I sure as heck wouldn't say that getting a new working image out the door is an easy task. It all takes time.
We'll be glad to have you join on IRC Raselin - there are now ~50 regulars and plenty of people pop by to ask for help and troubleshooting. Make sure to come by for the trivia challenge on the 5th - will be fun Wink
  Reducing Android Image download size. KPhillisJr 4 13,335 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,607 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,317 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 28,104 01-24-2017, 05:31 AM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,407 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,498 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,361 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 9,092 09-04-2016, 12:05 PM
Last Post: Boring
  MicroSD Size mismatch with Image Hbtr 23 47,671 08-31-2016, 09:00 AM
Last Post: montero65
  Android 5.1.1 Image Release 20160711 clarkss12 27 55,667 08-27-2016, 08:14 AM
Last Post: neyron
