How to import contacts with a .vcf file?
Howdy,
When I first ran Phosh and began setting things up, the Contacts app had me chose a contacts list and gave me the option to import a contacts list from a file.
Now that I has restarted and finished setting things up, I can't find a menu option to import a contact list from a file.
I have a list downloaded on the phone, but if there is a help file or a how-to, I can't find it.
How about doing it from the command line?
Thanks for any help!
IIRC you can load evolution on PMos: load it, import the vcf, then remove it.
(11-20-2021, 02:59 PM)LNXGUY Wrote: Howdy,
Currently there is only 'evolution' that could import contact list in vcf format. Place the vcf file in your home directory. Install it using apk:-
sudo apk add evolution
scale-to-fit evolution
evolution -i contacts.vcf
sudo apk del evolution
  How to create a file on the SD card I can modify on my Ubuntu PC? Peter Gamma 0 2,349 06-16-2024, 02:33 PM
Last Post: Peter Gamma
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 7,333 08-25-2023, 02:05 AM
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 2,945 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  File Manager that Can Access FTP Local Network? jakfish 1 3,022 02-19-2023, 02:31 PM
Last Post: jakfish
  File selector dialogue crashes Firefox stozi 1 4,449 11-22-2020, 01:40 AM
Last Post: quantumphoton
  "save as" dialog file browser crashed and gone quantumphoton 0 2,882 10-25-2020, 06:50 PM
