Does GPS work on a separate chip or is GPS built into the LTE modem?
Hi.
Pinephone.
(11-02-2021, 09:58 AM)Mikoduso Wrote: Hi.
Pinephone.
in the LTE modem module.
(11-02-2021, 06:03 PM)tllim Wrote: in the LTE modem module.
Thx.
Is Quectel firmware proprietary? Open firmware for Quectel modems does not exist?
Yes. It exists. Look the Boktorgs firmware on github.
To clarify on the firmware a bit, the phone arrives with Quectel's proprietary firmware installed because that's required for regulatory approval. The open firmware replaces the supervisory part of the modem firmware, but still uses the Qualcomm binary firmware for the radio layer.
https://github.com/Biktorgj/pinephone_modem_sdk
(11-08-2021, 03:08 AM)wibble Wrote: but still uses the Qualcomm binary firmware for the radio layer
Thanks.
Is it possible to replace the radio firmware?
Pinephone.
Why was it decided to use the GNSS module as part of the LTE modem, and not separately?
Indeed, if the radio modem has a backdoor for remote connection and control, then the functionality of the GNSS module can be disrupted and the coordinates will not be correct.
Thanks.
In theory a sufficiently well skilled, resourced and motivated team might be able to do it. In practice I'm not aware of anyone having done so - the skill and resource barriers are pretty high. The closest I'm aware of is OpenBTS.
Pinephone.
Many (most?) LTE modems now have GNSS built in. Using a separate GNSS module means extra cost, board space and power usage. For most people that's a poor trade as their threat model just isn't that extreme. You still wouldn't know whether that GNSS module's firmware had a backdoor via one of its RF interfaces, so you might instead insist on a software defined radio implementation. Even that doesn't help when someone starts messing with the GNSS signals, as is apparently not uncommon in some parts of the world.
(11-22-2021, 05:30 AM)wibble Wrote: In theory a sufficiently well skilled, resourced and motivated team might be able to do it. In practice I'm not aware of anyone having done so - the skill and resource barriers are pretty high. The closest I'm aware of is OpenBTS.
I assume that all radio medems have a 100% backdoor programmed for special services
(11-22-2021, 05:30 AM)wibble Wrote: You still wouldn't know whether that GNSS module's firmware had a backdoor via one of its RF interfaces
Intelligence agencies constantly abuse the control of phones and smartphones through the radio module
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 17,912 12-12-2025, 03:27 AM
  Modem Issues with the Pinephone Temmie19 5 4,939 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 4,605 02-05-2025, 02:30 AM
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 1,931 10-14-2024, 03:34 PM
Last Post: luxgiammi
  Supported Carrier and Modem Bands NachoMomma 4 7,336 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,488 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,302 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 7,996 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 13,387 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 7,149 07-06-2022, 12:35 PM
