Music stops playing when screen goes off and session gets suspended
so at least I suspect what the thread subject says. How can I keep listening to music while screen is off for a longer time?
I found, that adding a user to group 'music' should do the trick like
sudo adduser <username> audio
but what I get is:
sudo: adduser: command not found
Currently I'm on Pinephone KDE (Manjaro/Plasma Mobile):
KDE Plasma Version: 5.22.5
KDE Frameworks Version: 5.86.0
Qt Version: 5.15.2
Kernel Version: 5.14.10-1-MANJARO-ARM
Thanks for any advice!
EDIT: That DID NOT do the trick. As soon as the sesssion is suspended, the music stops. Even though I set 'Suspend Session' to 'never'.
So the questiom remains open: How to keep music playing while screen is off?
(10-20-2021, 03:41 AM)jojuma Wrote: Hi,
but what I get is:
Qt Version: 5.15.2
In Manjaro:
sudo gpasswd -a user group
After a while of trial and error, I came across the app 'Elisa', which plays radio streams as well as my music collection. It is able to play even if the screen is turned off. That's what I was looking for and even though the issue is not solved in general, I mark it solved for now.
  screen brightness Uturn 1 4,156 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 3,120 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,512 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 11,577 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 5,254 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 16,083 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 2,620 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 12,510 03-05-2022, 06:21 AM
Last Post: dcinoz
  Phone goes to sleep whilst audio playing new2pinephone 0 2,716 12-22-2021, 05:50 PM
Last Post: new2pinephone
  Manjaro Welcome screen landscape JohanB89 2 4,816 11-12-2021, 01:13 AM
Last Post: acrux
