LCD Touch Screen Problem.
What I have:
The pine A64 board.
LCD Touch Screen
San Disk 32gb microSD card
Power = 2.4AMP
I tried all the pins, and the LCD just stays white. The pine board works fine with hdmi.
Do I not have enough power to power the LCD or is it something else?
I have also booted Android 5.1.1 at least once.
(05-23-2016, 02:36 PM)Gavin Wrote: What I have:
The pine A64 board.
LCD Touch Screen
Power = 2.4AMP
Hey there. Welcome to the forum.
I think the issue is that you are trying to use a display designed for a Raspberry Pi for the Pine64. Whereas the Pi knows how to 'talk' with the screen, the Pine64 does not, because it was not designed to do so.
A further issue may be regarding resolution. Even if the Pine were somehow to utilise the screen, the resolution it offers is not one that is supported by any of the operating systems that are available, unfortunately.
I appreicate it @Ghost. I might have to buy the default LCD that Pine makes it looks like.
(05-23-2016, 03:38 PM)Gavin Wrote: I appreicate it @Ghost. I might have to buy the default LCD that Pine makes it looks like.
Yeah, sorry about that, but currently the default Pine screen is the way to go. That may not be the case for the future, but that's the situation as it is right now.
The pine A64 board.
LCD Touch Screen
Power = 2.4AMP
You need separate Android build for the LCD panel, please download from the pine64 wiki page and stated for LCD. Here is the direct link: http://files.pine64.org/os/android/andro...ixCard.zip
Gotta agree with Ghost as there are certain resolutions the device can output to I'm not sure the LCD has one of the supported resolutions.
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Further info on the HDMI side of things.
Here are the display resolutions available
{HDMI1440_480I, 0,13500000, 1, 720, 480, 858, 57, 19, 62, 525, 15, 4, 3, 0, 0, 1, 0, 0},
{HDMI1440_576I, 0,13500000, 1, 720, 576, 864, 69, 12, 63, 625, 19, 2, 3, 0, 0, 1, 0, 0},
{HDMI480P, 0,27000000, 0, 720, 480, 858, 60, 16, 62, 525, 30, 9, 6, 0, 0, 0, 0, 0},
{HDMI576P, 0,27000000, 0, 720, 576, 864, 68, 12, 64, 625, 39, 5, 5, 0, 0, 0, 0, 0},
{HDMI720P_50, 0,74250000, 0, 1280, 720, 1980, 220, 440, 40, 750, 20, 5, 5, 1, 1, 0, 0, 0},
{HDMI720P_60, 0,74250000, 0, 1280, 720, 1650, 220, 110, 40, 750, 20, 5, 5, 1, 1, 0, 0, 0},
{HDMI1080I_50, 0,74250000, 0, 1920, 1080, 2640, 148, 528, 44, 1125, 15, 2, 5, 1, 1, 1, 0, 0},
{HDMI1080I_60, 0,74250000, 0, 1920, 1080, 2200, 148, 88, 44, 1125, 15, 2, 5, 1, 1, 1, 0, 0},
{HDMI1080P_50, 0,148500000, 0, 1920, 1080, 2640, 148, 528, 44, 1125, 36, 4, 5, 1, 1, 0, 0, 0},
{HDMI1080P_60, 0,148500000, 0, 1920, 1080, 2200, 148, 88, 44, 1125, 36, 4, 5, 1, 1, 0, 0, 0},
{HDMI1080P_24, 0,74250000, 0, 1920, 1080, 2750, 148, 638, 44, 1125, 36, 4, 5, 1, 1, 0, 0, 0},
{HDMI1080P_25, 0,74250000, 0, 1920, 1080, 2640, 148, 528, 44, 1125, 36, 4, 5, 0, 0, 0, 0, 0},
{HDMI1080P_30, 0,74250000, 0, 1920, 1080, 2200, 148, 88, 44, 1125, 36, 4, 5, 0, 0, 0, 0, 0},
{HDMI1080P_24_3D_FP, 0,148500000, 0, 1920, 2160, 2750, 148, 638, 44, 1125, 36, 4, 5, 1, 1, 0, 45, 1},
{HDMI720P_50_3D_FP, 0,148500000, 0, 1280, 1440, 1980, 220, 440, 40, 750, 20, 5, 5, 1, 1, 0, 30, 1},
{HDMI720P_60_3D_FP, 0,148500000, 0, 1280, 1440, 1650, 220, 110, 40, 750, 20, 5, 5, 1, 1, 0, 30, 1},
{HDMI3840_2160P_30, 0,297000000, 0, 3840, 2160, 4400, 296, 176, 88, 2250, 72, 8, 10, 1, 1, 0, 0, 0},
{HDMI3840_2160P_25, 0,297000000, 0, 3840, 2160, 5280, 296, 1056, 88, 2250, 72, 8, 10, 1, 1, 0, 0, 0},
{HDMI_EDID,},
there are entries in the sources (linux kernel longsleep) that indicate it should handle the lcd. What I am wondering is if android is currently limited at the moment.
Have you attempted using the lcd in linux as of yet?
Cheers Big Grin
(05-23-2016, 02:36 PM)Gavin Wrote: The pine A64 board.
LCD Touch Screen
You would need the appropriate driver for this type of SPI devices to get a simple framebuffer device (forget about the other answers, especially HDMI and the totally different Pine64 LCD module): https://github.com/notro/fbtft/wiki
That means a patch like this has to applied to kernel sources (this patch is against another 3.10.y kernel but a 32-bit variant so it might require some tweaks). And then you should keep in mind that the fps of such an SPI display are pretty low so in case you want to use an LCD that is fully useable (or you have no experience in compiling Linux kernels or just want to run Android) there is no alternative to the official LCD.
TL;DR: In Pine64's current state (kernel drivers, support 'quality' by moderators here in the forum) you can forget about using any cheap/small SPI display with this board.
The pine A64 board.
LCD Touch Screen
Power = 2.4AMP
Number one probable cause why LCD turns bright without image, its because theres a problem with your physical connection from your pine board to the LCD.I got this problem before and solved it by changing the orientation extension board (small board that has only two connectors that links between the LCD ribbon and the main board ribbon).
  Is there a screen for the Rockchip RK3399 that works with FreeBSD out of the box ? ziomario 0 1,701 11-10-2024, 02:06 AM
Last Post: ziomario
  7 inch LCD touch panel is upside down? joshpl 2 5,200 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 5,436 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 58,046 07-21-2017, 07:41 AM
Last Post: apple4ever
  [Problem] help find R110~R113 resistors on board to LCD Rotation 180deg msmmbl 2 7,258 07-21-2017, 12:00 AM
Last Post: msmmbl
  I2C Touch Panel mbt28 0 3,565 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD screen brightness/contrast Learnincurve 10 22,405 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 10,635 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 32,608 12-07-2016, 07:47 AM
Last Post: Luke
  Screen flashes blue and then goes dark. tanarri 5 13,139 06-22-2016, 10:53 AM
Last Post: tanarri
