Choosing Wi-Fi or Mobile Data
Does anyone know if the phone is connected to both Wi-Fi and has mobile data turned on is it smart enough to use Wi-Fi? I am always on Wi-Fi and just got a note from my provider claiming I've used half my data. I'm running Mobian, with the necessary patches to receive MMS messages (I mention this because I think the MMS eats into my data, even though it's supposed to be unlimited text). Any help is appreciated!
I was looking into this a while back because I had a similar issue. Here is what I found.
Wifi should be preferred since it has lower metric values in the routing table (or at least it should have). However I noticed that if IPv6 wasn't available on the wifi network, mobile data was used instead since IPv6 seems to be prioritized over IPv4. My workaround still is disabling IPv6 for the mobile data connection, so it doesn't matter if the wifi network supports IPv6.
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 12,003 10-24-2023, 08:57 AM
Last Post: Peter Gamma
  Proximity lock on Plasma Mobile alpineduck 0 2,502 08-14-2023, 05:51 PM
Last Post: alpineduck
Information Quick&dirty VPN quick setting button for Plasma Mobile Kevin Kofler 0 2,616 04-06-2023, 02:40 PM
  Mepo - Minimalist and hackable OSM map viewer for mobile linux mil 22 31,667 10-31-2022, 07:29 AM
Last Post: mil
  Help wanted: location of calls and chatty data files dukla2000 3 8,555 06-13-2022, 02:01 PM
Last Post: israel
  HowTo: Get a passcode from DUO Mobile working on the Pinephone kop316 2 7,150 01-16-2022, 03:46 PM
Last Post: michel_luc
  GTK Rust mobile Linux client for Signal Be. 14 36,124 11-11-2021, 05:35 PM
Last Post: sativista
  Questions and experiences using Fedora Mobile (as a PinePhone newbie) zkajdan 1 3,573 10-03-2021, 11:31 AM
Last Post: zkajdan
  Plasma Mobile goes back to lockscreen when the phone isn't charging plaristote 4 8,202 06-12-2021, 09:06 AM
Last Post: plaristote
  PinePass - Mobile friendly GUI for pass mpnordland 2 5,978 05-01-2021, 05:46 PM
Last Post: linmob
