12-12-2015, 12:19 PM
By the looks of it, the Pine64 boards don't support Optical SPDIF via the 3.5mm Jack, only SPDIF via the 'euler' bus connector. Is this correct?
The low-cost "Chromecast Audio" device supports optical SPDIF via its 3.5mm jack, so my thought is that the physical component isn't too expensive (if you can find the source for it). It would be nice to have/tout SPDIF support without having to create a daughter card.
What are your thoughts?
