On-Screen Keyboard Arrow Keys
(03-27-2025, 10:51 AM)merom Wrote: Hi.
I made squeekboard/keyboards/terminal folders as recommended, using Portfolio. Then I copied the us.yaml file to the
~/.local/share/squeekboard/keyboards/terminal/
folder, and this is also possible using Portfolio. There was a situation that it didn't work. I realized that you need to uninstall Addon Phosh OSK via the software app.
Finally, it is necessary to log out the user or restart the system.
This is seen in the attached pictures, you can try the same.
OK, we are back to my good keyboard setups now!! thanks!
(03-04-2025, 09:47 PM)mikehenson Wrote:
(03-04-2025, 03:35 PM)biketool Wrote: With the current Phosh the included on-screen terminal keyboard has changed and while most of the improvements are great where is my unix up-key?
I like to up/down to scroll for my previous inputs. Also what is the left/righ arrow key next to A?
With phosh and squeekboard, just create your own layout. Here is mine.
https://github.com/mikeshenson/Phosh-Squ...d-Keyboard
On finding the "new and improved" keyboard in Trixie I immediately returned back to squeekboard. Precisely as the "Terminal" layout on the default OSK was so bad.
There are instructions as to how to go back to squeekboard this in one of the Wikis.
TBH I have never been terribly impressed with squeekboard but apparently it seems that developers can enshittify anything these days.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,813 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,538 12-23-2025, 04:34 AM
  How to add an homemade app to the main screen? JChdeL 3 2,593 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,768 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,747 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 6,276 01-14-2025, 02:49 AM
  New keyboard issue sandspur 30 41,735 01-13-2025, 01:37 AM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,987 08-05-2024, 06:12 AM
Last Post: baptx
  Keyboard not popping up on QT apps 3x5co 1 3,518 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 2,584 12-26-2023, 06:08 AM
Last Post: mdk
