manual install archlinux
(04-15-2025, 07:11 AM)tophneal Wrote:
(04-15-2025, 06:49 AM)TestaMic Wrote: I haven't been able to boot those images either, booting from SD Card.
Is there a way to manually install, but get that HDMI display support that these images have?
Thanks!
you should get that out-of-the-box with the manual arch install. the a64 has mainline kernel support, so you shouldn't have to do anything extra to utilize the hdmi output.
On the arch website (instructions for pine a64+), it says that HDMI "is not supported by the main kernel yet", and the packages downloaded to make the image are not updated from 2018, and when booting, hdmi indeed dosen't work.
Any way to make it working?
(04-15-2025, 07:47 AM)TestaMic Wrote: On the arch website (instructions for pine a64+), it says that HDMI "is not supported by the main kernel yet", and the packages downloaded to make the image are not updated from 2018, and when booting, hdmi indeed dosen't work.
Oh, my bad, I missed that in the notes.
It's older, but you could try longsleep's kernel or one of their arch imgs https://www.stdin.xyz/downloads/people/l...linux/OLD/
they should have patches/drivers to get hdmi working
I'll try that, but idk why i remeber BSP kernel having nonfunctional HDMI. I'll try and let you know.
  Archlinux VLC AUDIOTEK 5 14,662 01-30-2019, 02:36 PM
Last Post: michaelj
  how about this non-offical archlinux ? joe 1 7,900 02-12-2017, 10:03 PM
  Kodi on Archlinux arm? mike-bar 5 16,516 05-06-2016, 04:26 PM
Last Post: lenny.raposo-pine64.pro
  Archlinux up and Running scnd 4 11,673 04-30-2016, 06:42 PM
Last Post: Leoncito81
