Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image)
Thanks! Doing it all without ModemManager is a very interesting solution!
I did manage to find a bit of a less intrusive solution (cross-posting from https://todo.sr.ht/~mil/sxmo-tickets/73):
This requires less adaptation and doesn't ditch ModemManager: Starting modemmanager with a bit more verbosity helps (--debug also does the trick too but is even more verbose).
--- /etc/init.d/modemmanager
+++ /etc/init.d/modemmanager @@ -2,6 +2,7 @@
 supervisor=supervise-daemon command=/usr/sbin/ModemManager
+command_args="--log-file=/var/log/modemmanager.log --log-level=INFO"
 description="ModemManager Daemon"
I don't really understand why ModemManager fails without these options. I I had tried downgrading it but that didn't help either. For now this seems a pretty acceptable solution, having a log seems appropriate anyhow, so maybe we should merge this into sxmo (although it's technically not an sxmo issue).
RE: Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image) - by proycon - 09-20-2020, 05:31 AM
  PostmarketOS sxmo pinephone keyboard keymaps? afwtioane 2 2,082 09-11-2022, 04:37 AM
Last Post: manubert
  sxmo pim nextcloud Uturn 8 6,148 02-22-2022, 03:23 PM
Last Post: TRS-80
  Battery life on sxmo xark 1 2,117 02-12-2022, 10:07 AM
Last Post: TRS-80
  Official Channels for Sxmo Support anjanmomi 2 3,103 02-12-2022, 09:50 AM
Last Post: TRS-80
  sxmo & php --- 2 1,808 01-31-2022, 01:45 PM
Last Post: ---
  sxmo improvements unrealb2 7 5,751 11-17-2021, 06:43 AM
Last Post: fdlamotte
  SXMO on Debian IVp 0 2,197 08-21-2021, 02:33 PM
Last Post: IVp
  Megi's multiboot sxmo image aithal 1 2,203 06-14-2021, 08:07 AM
  SXMO svkbd with joypad layout [for basic dosbox play] streak 0 1,502 05-27-2021, 08:47 AM
Last Post: streak
  Sxmo on Arch IVp 4 6,471 05-19-2021, 03:18 AM
Last Post: dukla2000
