USB Type-C connector overmold conflicts with the back cover
(05-09-2020, 06:26 PM)ngkz Wrote: I found that the plug overmold conflicts with the back cover when using the cable with a short plug (6.6mm). It charges the phone, but the retention mechanism is loose and the cable falls out when it swings.
According to Universal Serial Bus Type-C Cable and Connector Specification Release 2.0 page 46, the minimum length of the type-c plug is 6.51mm, so PinePhone should accept this cable.
FYI the Type-C specification recommends >=0.05mm clearance between the exterior surface of the product and plug overmold.
Thanks, already ask product team looking into your suggestion.
RE: USB Type-C connector overmold conflicts with the back cover - by tllim - 05-10-2020, 12:19 AM
Question Alternative Designs or Materials for the Back Cover? BMayes 2 556 12-18-2023, 11:19 AM
Last Post: BMayes
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,329 10-12-2023, 01:03 PM
Last Post: robthebold
  USB-C connector Overheated and melted nickbenjones 2 1,333 05-26-2023, 06:16 PM
  GPS Antenna - external connector? GregH 14 11,622 09-09-2021, 09:24 AM
Last Post: HobanWashburn
  Fragile SIM card connector hakkou 1 1,808 08-25-2021, 07:44 AM
Last Post: wibble
  USB C connector loose? bceverly 3 2,967 08-10-2021, 09:44 AM
Last Post: c3l@
  Back cover plastic woes mteagles1942 6 6,512 03-28-2021, 10:19 PM
Last Post: NormandC
  Back cover with UBPorts logo cracked Phillip Bell 7 6,906 03-22-2021, 12:20 PM
Last Post: mteagles1942
  Micro-USB 3.0 connector for the PinePhone? Peter Gamma 1 2,147 03-10-2021, 10:11 AM
Last Post: wibble
  broken connector-pin for the accu alwi 2 2,790 02-23-2021, 06:28 AM
Last Post: scholbert
