replacing back-screw standoffs
(03-16-2020, 07:12 PM)sundog Wrote:
(03-13-2020, 01:56 PM)MIchael Wrote: It's been 30 years since drafting class and if you have any problems reading it let me know.
https://www.dropbox.com/s/blmvy6or9r0hhe...1.jpg?dl=0
https://www.dropbox.com/s/80ld7mvhy32qzw...2.jpg?dl=0
https://www.dropbox.com/s/9n7sdm1ah3r727...1.jpg?dl=0
https://www.dropbox.com/s/6i7genzs6r5246...4.jpg?dl=0
https://www.dropbox.com/s/hscizbic0svesy...0.jpg?dl=0
https://www.dropbox.com/s/q009s69wjfk0vy...8.jpg?dl=0
I know, it's terrible but it should give you a good idea.
Ohhhh, if you tape it down, I don't think you'd need the little alignment tabs. Super Glue might work too.
Okay, finally managed to squeeze in some time to give this a try, and...it worked!
I've published the STL on thingiverse under a CC0 license here: https://www.thingiverse.com/thing:4226648
All I did was lay it out in OpenSCAD using the measurements you provided converted into millimeters. The OpenSCAD code is:
// Pinebook Pro back screw standoff
// Version: 1
// Date: 2020-03-16
// Author: pine64 forum user sundog, based on
//         measurements provided by pine64
//         forum user Michael
// License: CC0
// resolution settings for display in openscad
$fa = 1;
$fs = 0.4;
// back right corner standoff
difference() {
   cube([6.9342, 7.9756, 1.2700], center=true); // the main piece
   cylinder(h=1.27,d=2.286, center=true); // the hole in the main piece
translate([(6.934/2)+(1.1684/2),0,(1.27/2)])
   cube([1.1684, 2.0574, 2.1844], center=true); // centered tab
translate([0, (-7.9756/2)+(0.7620/2), (0.9144/2)])
   cube([1.9812, 0.7620, 1.27+ 0.9144], center=true); // side tab
// back left corner standoff
translate([10, 0, 0])
   difference() {
   translate([0, (7.9756/2)-(0.7620/2), (0.9144/2)])
       cube([1.9812, 0.7620, 1.27 + 0.9144], center=true); // other side tab
This is my first OpenSCAD model, so if anyone wants to clean it up and refactor it into something nicer, feel free
A couple pics:
https://toot-lab.reclaim.technology/20200316_171829.jpg - back left corner standoff installed
https://toot-lab.reclaim.technology/2020...37_HDR.jpg - back right corner standoff installed
Thanks again for your help, @MIchael - my Pinebook Pro is fixed and I couldn't have done it without you!
My pleasure, glad I could help.
replacing back-screw standoffs - by sundog - 03-12-2020, 07:47 PM
RE: replacing back-screw standoffs - by MIchael - 03-12-2020, 09:47 PM
RE: replacing back-screw standoffs - by sundog - 03-13-2020, 09:46 AM
RE: replacing back-screw standoffs - by MIchael - 03-13-2020, 12:20 PM
RE: replacing back-screw standoffs - by MIchael - 03-13-2020, 01:56 PM
RE: replacing back-screw standoffs - by sundog - 03-13-2020, 02:25 PM
RE: replacing back-screw standoffs - by sundog - 03-16-2020, 07:12 PM
RE: replacing back-screw standoffs - by MIchael - 03-16-2020, 07:56 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 2,074 04-23-2023, 06:58 AM
Last Post: acruhl
  Replacing Manjero with Ubunto on a PBP john.ismyname 5 3,196 08-23-2022, 05:06 AM
  Back in Stock? bblackburn007 2 4,332 02-19-2020, 05:58 PM
Last Post: Luke
  Boot Issue after replacing EMMC M.Dayle 2 3,812 01-30-2020, 08:32 PM
Last Post: MIchael
  Pinebook missing screw from the factory tso4ev 4 6,383 01-20-2020, 01:25 PM
Last Post: Arwen
