How do you prevent the battery from discharging when the phone is off?
(03-11-2020, 12:15 PM)supermagic Wrote: When the phone is off, shouldn't all OSes stop functioning.... unless some component like the RTC maybe still on.
I use UBports too and the phone does discharge from like 100% to 60% in like 3 days when turned off.
When the phone is off, OS should stop functioning.
If something drains the battery, that may be caused by some hardware is not configured down perfectly and there is no power cut (transistor / FET) to power it down completely by hardware. At worst, some hardware may have some (higher or lower) power consumption even when it is configured down and that may cause battery to be slowly drained.
That is why it is a good idea to design the hardware in a way that a hardware switch could shut it down completely - especially if the hardware has non-removable battery which is luckily not the case here.
RTC may running, right, but it consumes extremely minimal power and that is a different part of the hardware.
RE: How do you prevent the battery from discharging when the phone is off? - by VaZso - 03-11-2020, 01:23 PM
  Phone powers off with high user demands car46999 7 724 04-11-2024, 09:17 AM
Last Post: zetabeta
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 608 02-17-2024, 04:15 PM
Last Post: vortex
  Phone will not turn on (but sometimes will) insidetrip101 10 4,974 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,119 07-31-2023, 07:50 PM
  Battery life improvement freelectro 10 3,508 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,586 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 1,218 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,166 02-20-2023, 12:14 AM
Thumbs Down Phone is unresponsive theneedful 14 7,928 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,764 08-11-2022, 11:52 AM
Last Post: auanta
