Can a PBP use GRUB?
Figured out how to automate it in a janky manner - details below for posterity. Still interested in getting grub to output to the LCD with keyboard input. When only letting grub see "console=tty1" in the bootargs, it spits out "error: no suitable video mode found." on the serial console right before displaying the boot menu.
boot.txt
setenv bootargs initrd=/boot/initramfs-linux.img console=ttyS0 console=tty1 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
load mmc 1:1 ${fdt_addr_r} dtbs/rockchip/rk3399-pinebook-pro.dtb
load mmc 1:1 ${kernel_addr_r} efi/EFI/BOOT/BOOTAA64.EFI
bootefi ${kernel_addr_r} ${fdt_addr_r}
You might need to change the "1:1" in the "load mmc" commands for your setup - for testing I was booting off an sdcard. Also note your paths to grubaa64.efi (BOOTAA64.EFI) and dtb file may be different.
grub.cfg
set timeout_style="menu"
set timeout=5
menuentry "Kernel" {
linux (hd0,msdos1)/Image console=tty1 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
devicetree (hd0,msdos1)/dtbs/rockchip/rk3399-pinebook-pro.dtb
initrd (hd0,msdos1)/initramfs-linux.img
As others online have noted, rebooting has issues but otherwise it seems to work great.
Here is my boot log too in case it might help someone:
U-Boot TPL 2020.01-6-g365495a329 (Mar 08 2020 - 16:47:50)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.01-6-g365495a329 (Mar 08 2020 - 16:47:50 +0000)
Trying to boot from MMC1
U-Boot 2020.01-6-g365495a329 (Mar 08 2020 - 16:47:50 +0000) Manjaro ARM
Model: Pine64 Pinebook Pro
DRAM:  3.9 GiB
PMIC:  RK808
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
## Error: Can't overwrite "serial#"
## Error inserting "serial#" variable, errno=1
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
452 bytes read in 5 ms (87.9 KiB/s)
## Executing script at 00500000
80426 bytes read in 16 ms (4.8 MiB/s)
135168 bytes read in 24 ms (5.4 MiB/s)
Scanning disk dwmmc@fe320000.blk...
Card did not respond to voltage select!
Scanning disk sdhci@fe330000.blk...
Disk sdhci@fe330000.blk not ready
Found 3 disks
Welcome to GRUB!
                                               GNU GRUB  version 2.04                                       [28/1829]
 │*Kernel        │
      Use the ▲ and ▼ keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands before booting or `c' for a command-line.
   The highlighted entry will be executed automatically in 0s.
  Booting `Kernel'
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
Can a PBP use GRUB? - by ab1jx - 02-23-2020, 09:29 AM
RE: Can a PBP use GRUB? - by tophneal - 02-24-2020, 08:29 AM
RE: Can a PBP use GRUB? - by ab1jx - 02-25-2020, 01:40 PM
RE: Can a PBP use GRUB? - by amiraeva - 03-18-2020, 05:03 PM
RE: Can a PBP use GRUB? - by amiraeva - 03-18-2020, 06:53 PM
