Heat build-up: EG25 or SOC?
After the first hour or so of playing w/ different OS images, the exposed RF-shield (under the battery cover) gets quite hot. I'm was pretty sure this shield only covered the EG25, so flipped the modem kill-switch to off. It's still getting quite hot... so I've got two questions (one of which I can probably answer from the schematics):
1) Does the RF-shield act as a heat-sink for both the modem *and* the SOC?
2) What does the modem kill-switch actually do to the modem? Place in reset? Physically remove power?
EDIT: Took a me a bit to realize that the symbol for the killswitches is split through-out. SW1-A is the 2-pins for the modem kill-switch, and looks like it is intended to cut power at the Q1500 power mosfet. Has anyone confirmed that the EG25 does not draw unwanted power when disabled?
Heat build-up: EG25 or SOC? - by CloudHackIX - 02-11-2020, 07:11 PM
RE: Heat build-up: EG25 or SOC? - by Alho - 02-11-2020, 09:36 PM
RE: Heat build-up: EG25 or SOC? - by aldude999 - 02-12-2020, 08:22 PM
RE: Heat build-up: EG25 or SOC? - by CloudHackIX - 02-17-2020, 07:39 AM
RE: Heat build-up: EG25 or SOC? - by CloudHackIX - 02-24-2020, 08:52 PM
  firmware udate Quectel EG25-G modem alwi 7 5,351 07-06-2022, 01:43 PM
Last Post: user641
  CVE-2021-31698 - Quectel Eg25-g AT Command Injection jtn0514 2 3,401 09-30-2021, 12:26 PM
Last Post: megous
  Quectel EG25-G H/W interface - Operating Modes - eg25-manager mouffa 0 1,957 06-23-2021, 06:57 AM
Last Post: mouffa
  Quectel EG25-G GNSS Configuration and location tracking mouffa 2 5,800 06-07-2021, 04:24 AM
Last Post: mouffa
  Quectel EG25-G Modem Configuration - ofono - Manjaro Plasma mouffa 5 4,538 06-02-2021, 11:38 AM
Last Post: mouffa
  Build own smartphone based on PinePhone64 mainboard and its components? docomodo 3 3,610 12-23-2020, 08:15 AM
Last Post: hcal
  EG25-G support for emergency alerts (WEA/CMAS) newton688 5 6,736 07-01-2020, 11:35 AM
Last Post: wibble
