Suspend with NVME not working - Default Debian
(07-12-2020, 01:47 AM)johnny89 Wrote:
(02-06-2020, 08:06 PM)Jeremiah Cornelius Wrote: This is probably related to the same nvme issues I solved for Linux on the Macbook Pro, recently. The drive would "sleep" but then resume as read-only - with unpredictable effects!
The Macs don't support APST, and many nvme units also seem to be "idiosyncratic" about implementations. The fix is to "turn-off" the ability of the kernel to impose sleep states on hardware that does not conform.
After researching a bit about this, my solution was:
echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
This is now featured on the authoritative  Dunedan /mbp-2016-linux github: https://github.com/Dunedan/mbp-2016-linux
This needs to be done in a root shell, sudo user won't cut it. You can elevate by runing 'sudo su -' and have a root shell, without additional login process.
I'd seriously give this a shot, AFTER you determine with lspci the actual device number for your nvme.
If this solves your problem, I supplied scripts and a systemd service wrapper, so you may automate at boot:
https://github.com/cb22/macbook12-spi-dr...-540208177
Create this file:
Quote:/etc/systemd/system/fix_sleep.service
# systemd oneshot service to set sleep boolean on Apple Macbook Pro disks
# Original by Pier Lim. Posted at https://kerpanic.wordpress.com/2018/03/1...in-ubuntu/
   [Unit]
   Description=Job that disables sleep from stopping nvme hardware on MBP
   [Service]
   ExecStart=/sbin/fixsleep
   Type=oneshot
   RemainAfterExit=yes
   [Install]
   WantedBy=multi-user.target
And the actual script:
Quote:/sbin/fixsleep
#!/bin/bash
/bin/echo 0 > /sys/bus/pci/devices/0000\:01\:00.0/d3cold_allowed
If you try this out, I'd love to hear how it goes.
Hi Jeremiah,
Your suggestion works on imac models that have unofficial nvme setup running Debian. Do you have knowledge as to implementing same mechanism in macos since the issue is ongoing there as well. setpci maybe?  Any clues?
Thanks,
I'm afraid I'm way more familiar with being able to tinker with kernel internals of Linux, than MacOS.
— Jeremiah Cornelius
RE: Suspend with NVME not working - Default Debian - by Jeremiah Cornelius - 07-14-2020, 01:53 PM
  Use SD to install new OS over pinebook debian Rudy558 10 14,956 03-09-2025, 11:17 AM
Last Post: davisthomas
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 1,455 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 1,580 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 395,493 05-12-2023, 06:09 AM
Last Post: korreckj328
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 3,186 04-23-2023, 06:58 AM
Last Post: acruhl
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 1,310 12-09-2022, 04:48 PM
Last Post: River
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 1,441 10-08-2022, 11:03 AM
Last Post: omarcomputing
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 266,652 09-27-2022, 07:41 AM
Last Post: olyavi
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 4,144 06-29-2022, 02:00 PM
Last Post: Chief
  Selling Pinebook Pro (ISO) + nvme from Sweden DavidL 5 5,146 06-20-2022, 03:20 PM
Last Post: DavidL
