Can't access login
I'm not sure where you would delete the photo from command line so maybe someone here can chime in but when it's booted you can press ctrl+alt+F1 to get into the terminal and navigate to that location to remove. Then either type logout or press ctrl+alt+f7 to get back. Hope this gets you in the right direction. Good luck
Can't access login - by evj - 01-26-2020, 11:08 PM
RE: Can't access login - by FeMike - 01-28-2020, 08:48 AM
RE: Can't access login - by evj - 01-28-2020, 09:48 PM
RE: Can't access login - by FeMike - 02-03-2020, 07:01 AM
  First access denied IMSAI8080 3 3,286 06-07-2021, 01:08 PM
  Graphical login hanging after password entry mhill8 2 3,408 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  PBP Went Blank After Login iscmob 2 3,029 12-07-2020, 09:28 AM
Last Post: iscmob
  Private Internet Access VPN on Pinebook Pro 11Eleven 13 15,508 10-27-2020, 05:35 PM
Last Post: AronShap
  Pinebook Pro Won't Accept Login GFreeman 16 16,729 09-03-2020, 11:44 AM
  Login screen issue. LinuXchoicE 2 4,167 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Stuck on login screen Kscott6969 0 1,942 04-20-2020, 10:58 PM
Last Post: Kscott6969
  default os: loop while login as rock gritibaenz 8 8,336 03-10-2020, 03:14 PM
Last Post: gritibaenz
  The usage/access of the SPI flash aaspectre 2 3,756 01-06-2020, 08:14 AM
Last Post: aaspectre
  Wrong keyboard Lay-out in Login and terminal Firedevil79 1 3,176 12-04-2019, 08:50 AM
Last Post: ndp
