Pinebook Pro Revised Keyboard Firmware
#60
Is there a way to make Fn+F3 do what is suggested by its icon? I think it should send KEY_SWITCHVIDEOMODE defined in /usr/include/linux/input-event-codes.h file, but I can't find anything similar in include/keycodes.h.
EDIT:
OK, I 've figured it out. First I've changed keyboard firmware so it would send F15 when Fn+F3 is pressed, it will send 6a, then I've created file /etc/udev/hwdb.d/90-usb-kbd-custom.hwdb with contents:
evdev:input:b0003v258Ap001E*
  KEYBOARD_KEY_7006a=switchvideomode
It will translate F15 to KEY_SWITCHVIDEOMODE (but first I had to run: sudo systemd-hwdb update).
Now Fn+F3 works like Meta+P (in KDE).
I've tried with 0xBF because it was not used, but it was not send, either.
RE: Pinebook Pro Revised Keyboard Firmware - by wrzomar - 10-15-2020, 10:22 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 549 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 346 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 290 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 627 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,109 11-07-2023, 10:09 AM
Last Post: DrYak
  Separate ISO keyboard for PBP Besouro 0 716 06-04-2023, 02:51 PM
Last Post: Besouro
  PineBook Pro dead ottahe 9 6,042 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,450 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,816 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,910 10-21-2022, 07:57 AM
Last Post: dachalife
