Pinebook Pro Revised Keyboard Firmware
#47
(03-20-2020, 01:21 PM)wdt Wrote: >- reboot with complete shutdown for a couple of minutes
Question,, is this the shutdown from HOLDING pwr button for 15+ seconds? (for me, 20+sec),
for a COMPLETE shutdown?
Did you avoid starting  X, at dm (sddm, ldm,whatever) DON'T login, switch to vt and login root?
You could try single mode, add "1" (no quotes) to kernel cmd line in extlinux.conf,
if successful login will be text mode in vt1
(if boot.txt/boot.scr need to recompile scr, with uEnv maybe just in that)
ok, tried that:
systemctl disable lightdm # so do dm was running anymore after boot
  • as you said, after a shutdown I held the POWER Button 20 seconds
  • executed step-2 after reboot and then I got a segmentation fault
  • Then I started from the beginning again with step-1 a couple of times but now after step-2 the verify mismatch error occurs again
I didn't manage to start in single mode, I added the 1 to the /sbin/init 1 command but then on boot I only got a black screen
RE: Pinebook Pro Revised Keyboard Firmware - by cloudnaut - 03-21-2020, 01:51 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 537 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 336 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 280 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 614 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,081 11-07-2023, 10:09 AM
Last Post: DrYak
  Separate ISO keyboard for PBP Besouro 0 710 06-04-2023, 02:51 PM
Last Post: Besouro
  PineBook Pro dead ottahe 9 6,003 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,415 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 135,504 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,891 10-21-2022, 07:57 AM
Last Post: dachalife
