Charger not included?
(01-03-2020, 02:52 PM)fnl Wrote: I just received my Pinebook Pro, which I ordered without any extras. There doesn’t seem to be even a power plug or other charging cable included. Is that correct and do I need to order that separately? If so, what are the required specs to buy a charger (in Europe).
 Yes it does or should have an included charger,  that uses the barrel type connector  (measurements are in the Wiki)
   But there is an alternate method to run and or charge your PBP from the usb-c port.
Just that it needs to be a minimum of 15 watts,  a new/newer smart phone charger  could work for this,
        at least until you sort out what happened to the charger that was supposed to come with your new laptop.
 But,  make sure you only use one power source at any one time...  !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Charger not included? - by fnl - 01-03-2020, 02:52 PM
RE: Charger not included? - by tophneal - 01-03-2020, 02:55 PM
RE: Charger not included? - by fnl - 01-03-2020, 03:00 PM
RE: Charger not included? - by tophneal - 01-03-2020, 03:06 PM
RE: Charger not included? - by fire219 - 01-03-2020, 03:53 PM
RE: Charger not included? - by bcnaz - 01-03-2020, 09:09 PM
RE: Charger not included? - by fnl - 01-04-2020, 04:47 PM
RE: Charger not included? - by chip ling - 01-16-2020, 09:46 PM
RE: Charger not included? - by brzegorz - 01-05-2020, 04:05 AM
  Sanity check on spliced charger jcun4128 12 3,021 05-10-2023, 05:23 AM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,964 10-21-2022, 07:57 AM
Last Post: dachalife
  Blinking red light for charger, no power-on bifo 11 14,012 11-30-2021, 01:37 PM
  USB fast charger HelpMyBatteryIsDraining 1 2,210 06-14-2021, 09:44 PM
  Is it safe to use a charger with more than 3A output? Obikawa 8 9,591 01-14-2020, 02:32 PM
Last Post: zaius
