Mainline U-Boot with SPI, NVMe and SATA boot support
#76
(04-15-2021, 10:46 AM)sigmaris Wrote:
(04-15-2021, 05:04 AM)MisterA Wrote: I'm currently experiencing problems booting the latest Armbian release on my rockpro64 from eMMC.
I just hangs like you can see on the photo on the first comment in this forumthread:
https://forum.armbian.com/topic/14724-ro...-v44-does/
Would this u-boot also solve that problem? Currently booting from SDCard but would prefer eMMC of course.
If you're using Armbian, probably best to stick with Armbian's U-Boot. It makes things simpler and Armbian volunteers probably don't want to support mixing other builds of U-Boot with Armbian Linux.
FWIW, if you're seeing log messages about /scripts/local-premount and so on like in the photo, that's booted up the Linux kernel and got as far as running the scripts on initramfs. So U-Boot may not be the issue here. I would suspect the scripts on initramfs are having trouble finding the root filesystem to mount it and continue booting. Look at your root= argument in the kernel command line, check it's specifying the filesystem you want, and see if you can enable more verbose logging (remove things like quiet from the kernel arguments) to get more information.
  I don't know if it is your case, it happened to me when I made an direct image of my emmc to boot from a ssd nvme : the root dev was indeed pointing on the emmc device instead on the ssd. I did not want to bother and downloaded the new image with the 5.10 kernel.
But I suppose that the good procedure would be to specify the root dev :
- get the uuid of the dev containing the root/ : "lsblk  -o NAME,PATH,MOUNTPOINT,UUID "
- in the file /boot/armbianEnv.txt change UUID of the line "rootdev=UUID=" with the UUID on the root or "/" mountpoint
RE: Mainline U-Boot with SPI, NVMe and SATA boot support - by LMM - 04-16-2021, 02:20 AM
  enble boot after power loss/restore dkebler 18 9,460 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 675 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,274 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,334 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,555 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,233 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,155 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,810 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,166 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 918 06-02-2022, 02:20 AM
Last Post: dmos
