Mainline U-Boot with SPI, NVMe and SATA boot support
#56
(10-18-2020, 07:56 PM)voltagex Wrote: Am I completely missing where the binaries are for this? You've skipped the GitHub release for that branch.
Additionally, is it possible to increase u-boot's debug level? It might help me solve an unrelated issue.
The binaries are published as build artefacts, attached to the build in Azure Pipelines - click on the "3 published" link on the build page I linked to before, to download them. As I said above, when v2.4 of ARM Trusted Firmware is released, I'll tag a Github release.
If you want a debug build, look at the build pipeline script (reference for the pipeline syntax) and other guides to building U-Boot from source, modify the source code to set the debugging/logging you want, and build it according to the same process.
RE: Mainline U-Boot with SPI, NVMe and SATA boot support - by sigmaris - 10-19-2020, 10:50 AM
  enble boot after power loss/restore dkebler 18 9,569 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,295 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,374 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,564 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,315 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,160 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,825 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,171 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 920 06-02-2022, 02:20 AM
Last Post: dmos
