Mainline U-Boot with SPI, NVMe and SATA boot support
#45
(07-26-2020, 05:33 AM)sigmaris Wrote: I've made another build based on 2020.07 using this branch, with a couple of additional patches:
Patch from Tian Yuanhao which allows compressed (gzip, etc) kernels to be loaded. No need to gunzip the default arm64 kernels to load them with u-boot anymore.
Patch from Jagan Teki which is supposed to enable USB-3 support on the USB-3.0 type A port. When testing this with the one USB-3 disk drive I have, it didn't seem to work, the disk drive wasn't detected in the USB-3.0 port. I'd be interested to hear if anyone else has success in using USB-3.0 devices in USB-3.0 mode with this. Note the USB Type C port is configured as OTG mode by default in the DTS, and so won't be used as a host port, so only the Type A port should be used for USB-3.0.
Build artifacts for MMC and SPI installation from this branch can be found here.
This works fine for me with USB3--  I  have attached the u-boot logs from booting a SANDISK extreme stick and then a Samsung portable ssd T150.  I was booting from SPI .  I also booted my NVME,  which I removed in order to boot the other devices,  since that is first in the boot order.   When not booting from the USB3,  the kernel recognizes the USB3 devices, just FYI.   Is there anything in particular I could do to help you debug your issue?
.zip   u-boot log-USB3.zip (Size: 2.14 KB / Downloads: 285)
RE: Mainline U-Boot with SPI, NVMe and SATA boot support - by belfastraven - 07-26-2020, 05:20 PM
  enble boot after power loss/restore dkebler 18 9,532 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 678 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,286 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,357 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,563 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,282 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,158 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,817 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,169 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 920 06-02-2022, 02:20 AM
Last Post: dmos
