Mainline U-Boot with SPI, NVMe and SATA boot support
#43
I've made another build based on 2020.07 using this branch, with a couple of additional patches:
Patch from Tian Yuanhao which allows compressed (gzip, etc) kernels to be loaded. No need to gunzip the default arm64 kernels to load them with u-boot anymore.
Patch from Jagan Teki which is supposed to enable USB-3 support on the USB-3.0 type A port. When testing this with the one USB-3 disk drive I have, it didn't seem to work, the disk drive wasn't detected in the USB-3.0 port. I'd be interested to hear if anyone else has success in using USB-3.0 devices in USB-3.0 mode with this. Note the USB Type C port is configured as OTG mode by default in the DTS, and so won't be used as a host port, so only the Type A port should be used for USB-3.0.
Build artifacts for MMC and SPI installation from this branch can be found here.
RE: Mainline U-Boot with SPI, NVMe and SATA boot support - by sigmaris - 07-26-2020, 05:33 AM
  enble boot after power loss/restore dkebler 18 9,498 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 677 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,277 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,341 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,559 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,246 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,156 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,813 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,166 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 918 06-02-2022, 02:20 AM
Last Post: dmos
