Looking to commission a new Chromium build (COMMUNITY BOUNTY)
From source code of chromium I figured out the command that actually runs to start VM behind the GUI when you install Linux (Beta):
sudo crosvm run \
--cpus 6 \
--mem 3000 \
--socket /run/crosvm.sock \
-r /run/imageloader/cros-termina/12371.22.0/vm_rootfs.img \
/run/imageloader/cros-termina/12371.22.0/vm_kernel
Where mem is the maximum memory vm allowed to use and the value is about 2/3 of all memory the memory. From journalctl output I found that vm cannot be started with the error: cannot allocate memory errno 12.. If you remove this mem option it actually starts!
I tried to enable compact memory flag like here: https://stackoverflow.com/questions/4646...-available. I also tried to play with other kernel flags (don't remember already).
Can you use Mac to build chromium? Or you did install Ubuntu on it?
RE: Looking to commission a new Chromium build - by obyknovenius - 01-04-2020, 05:29 AM
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 4,410 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Chromium OS 78? obyknovenius 2 7,219 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 8,229 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 4,727 11-04-2019, 08:38 AM
