(01-20-2020, 08:06 AM)PakoSt Wrote: Oh, maybe the warnings I've disabled are for swiftshader? The container is running, adb works and you can install apks but there is no graphics.
Alright, these are the folders of the anbox packages which compile for me. Extract them and you will find the pkgbuild + a compiled package inside the folders:
https://drive.google.com/folderview?id=1...My9owzQ-E0
I've made only a few changes with the biggest ones being:
- target my fork of anbox to disable the fail with warnings in anbox-git (as per these instructions: https://skmp.dev/blog/anbox-rpi4/ )
- target the anbox-image towards the arm64 one ( https://build.anbox.io/android-images/20..._arm64.img from the previous page)
- just target aarch64
I've left everything else as was on the Arch pkgbuilds
I just got the packages you sent me installed (ran out of room and had to play SD shuffle to expand my Manjaro install) have these been updated?
I was thinking earlier, after I came across this: https://geeks-r-us.de/2017/08/26/android...x-desktop/ that the Customize Android section might be something we need to do, since the Android img we're using came from Anbox, if might still need some of these adjustments. I'm about to give it a shot.
Quick note to anyone else who wants to try the steps on this page, pay close attention to the terminal commands on the page, you cannot copy/paste, they are riddled with spaces in places they shouldn't or don't need to be. Can't tell why, but noticed it when I was setting permissions for apps I moved into the Android image.
