Anyone tried Anbox-4-arm64 yet?
Not yet. In fact, after having so many issues that I couldn't troubleshoot effectively while using Anbox-Reborn from the AUR (I may still revisit it, as there is an arm64 Android build buried in the Anbox repo, and I believe the issue was caused by Anbox-Reborn wanting to use the standard x86 img,) I came across another potential option: SPURV. It's supposed to be like Anbox, but for Wayland (which I use.)
Since it builds Android, I've been using this guide to allow compiling Google Android sources on aarch64. I haven't made it very far into the guide, just got my Go and Ninja installed. I'm a bit stuck right now, as it calls for using emerge to replace the specific tools provided by Google with the locally installed versions. I've never run across the emerge command before, so I'm still looking into its proper usage in this case, so I don't bork my efforts.
My initial Anbox efforts were actually cut short, due to running out of free space. I should have some more/new externals to download source to, later this week. Once I do, I'm going to give building Anbox from scratch another shot, since there appears to be some tiny bit of arm64 support that has slowly crept into it over the last 6 months.
(Links to my resources added for anyone else curious to try.)
(12-22-2019, 03:42 AM)brent.thierens Wrote: I was just doing it. The problem right now are the kernel modules. While building them, it shows me:
Quote:DKMS make.log for anbox-1 for kernel 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310 (aarch64)
Sun Dec 22 10:35:49 CET 2019
make: Entering directory '/var/lib/dkms/anbox/1/build/ashmem'
make -C /lib/modules/4.4.190-1233-rockchip-ayufan-gd3f1be0ed310/build V=0 M=$PWD
make[1]: Entering directory '/usr/src/linux-headers-4.4.190-1233-rockchip-ayufan-gd3f1be0ed310'
  LD      /var/lib/dkms/anbox/1/build/ashmem/built-in.o
  CC [M]  /var/lib/dkms/anbox/1/build/ashmem/deps.o
  CC [M]  /var/lib/dkms/anbox/1/build/ashmem/ashmem.o
gcc: error: unrecognized command line option '-mgeneral-regs-only'
gcc: error: unrecognized command line option '-mcmodel=large'
scripts/Makefile.build:277: recipe for target '/var/lib/dkms/anbox/1/build/ashmem/ashmem.o' failed
make[2]: *** [/var/lib/dkms/anbox/1/build/ashmem/ashmem.o] Error 1
make[2]: *** Waiting for unfinished jobs....
scripts/Makefile.build:277: recipe for target '/var/lib/dkms/anbox/1/build/ashmem/deps.o' failed
make[2]: *** [/var/lib/dkms/anbox/1/build/ashmem/deps.o] Error 1
Makefile:1479: recipe for target '_module_/var/lib/dkms/anbox/1/build/ashmem' failed
make[1]: *** [_module_/var/lib/dkms/anbox/1/build/ashmem] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.4.190-1233-rockchip-ayufan-gd3f1be0ed310'
Makefile:8: recipe for target 'all' failed
make: *** [all] Error 2
make: Leaving directory '/var/lib/dkms/anbox/1/build/ashmem'
If you have any solution to this, I'll be happy to try this out!
I just remembered the Reborn OS packages would be a bigger headache for you, since it's Arch based.
Are you building the modules yourself, or from the morphis/anbox-support PPA?
Anyone tried Anbox-4-arm64 yet? - by tophneal - 12-16-2019, 02:53 PM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 12-22-2019, 03:26 AM
Anyone tried Anbox-4-arm64 yet? - by tophneal - 12-24-2019, 08:14 AM
RE: Anyone tried Anbox-4-arm64 yet? - by gleachkr - 12-26-2019, 11:41 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 12-26-2019, 12:48 PM
RE: Anyone tried Anbox-4-arm64 yet? - by gleachkr - 12-26-2019, 04:49 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 12-27-2019, 02:28 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-10-2020, 08:27 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-15-2020, 09:49 AM
Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-17-2020, 09:06 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-17-2020, 11:25 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-18-2020, 07:34 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-18-2020, 08:32 AM
RE: Anyone tried Anbox-4-arm64 yet? - by FrankWu - 03-02-2020, 09:40 AM
Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-18-2020, 10:34 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-18-2020, 07:52 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-18-2020, 08:22 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 08:06 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-20-2020, 08:26 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 08:39 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 08:45 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-20-2020, 08:50 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 08:55 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-20-2020, 12:11 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-20-2020, 02:09 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 07:09 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-20-2020, 08:49 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-21-2020, 02:57 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-21-2020, 10:59 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-25-2020, 08:07 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-29-2020, 08:18 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 01-30-2020, 05:17 PM
RE: Anyone tried Anbox-4-arm64 yet? - by FrankWu - 02-27-2020, 09:34 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 01-31-2020, 06:46 PM
Anyone tried Anbox-4-arm64 yet? - by tophneal - 02-02-2020, 08:38 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 02-05-2020, 04:24 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 02-05-2020, 07:41 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 02-05-2020, 08:02 AM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 03-18-2020, 09:47 AM
RE: Anyone tried Anbox-4-arm64 yet? - by FrankWu - 03-25-2020, 03:38 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 03-25-2020, 12:00 PM
RE: Anyone tried Anbox-4-arm64 yet? - by PakoSt - 03-31-2020, 03:15 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 04-01-2020, 06:05 AM
RE: Anyone tried Anbox-4-arm64 yet? - by poVoq - 05-17-2020, 08:17 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 05-19-2020, 06:17 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 07-21-2020, 06:57 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 08-30-2020, 02:42 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 08-31-2020, 06:01 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 08-31-2020, 11:05 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 08-31-2020, 11:47 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 08-31-2020, 01:55 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 08-31-2020, 02:12 PM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 09-02-2020, 05:32 AM
Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-02-2020, 05:50 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 09-02-2020, 11:46 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-02-2020, 12:04 PM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 09-02-2020, 12:58 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-02-2020, 02:45 PM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-08-2020, 06:46 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-08-2020, 06:54 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-08-2020, 06:58 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-09-2020, 08:03 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 09-10-2020, 09:39 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tophneal - 09-10-2020, 09:47 AM
RE: Anyone tried Anbox-4-arm64 yet? - by Idaho - 09-24-2020, 04:06 AM
RE: Anyone tried Anbox-4-arm64 yet? - by poVoq - 09-29-2020, 07:19 AM
RE: Anyone tried Anbox-4-arm64 yet? - by jiyong - 02-23-2021, 06:59 AM
RE: Anyone tried Anbox-4-arm64 yet? - by tllim - 03-01-2021, 01:35 PM
RE: Anyone tried Anbox-4-arm64 yet? - by Proant - 08-11-2021, 11:21 AM
  Compile of Anbox fails because kernel function kallsyms_lookup_name() is unexported Tsvi Bar-David 6 7,796 06-30-2020, 06:41 AM
