Hardening your Pinebook Pro software
A safer and simpler version is to remove the SSH server altogether. Unless you need to SSH into your pbpro, this should be the recommended approach:
sudo apt-get purge openssh-server
Use "purge" instead of "uninstall", so that all configuration files and pregenerated keys are also removed.
Note that the ssh client remains installed, so you can still SSH to remote machines as usually.
Hardening your Pinebook Pro software - by Arwen - 12-07-2019, 03:33 PM
RE: Hardening your Pinebook Pro software - by jpakkane - 12-07-2019, 03:41 PM
RE: Hardening your Pinebook Pro software - by hdk - 12-11-2019, 09:53 AM
  Pinebook Pro Recovery with Void Linux (xbps) bds 0 556 01-14-2024, 10:21 PM
Last Post: bds
  Write SD cards with Etcher for Pinebook Pro futurejones 17 30,105 03-19-2021, 12:52 AM
Last Post: Alex007
  [GUIDE] ArchLinuxARM on Pinebook Pro hku2 10 19,590 12-25-2020, 05:44 AM
Last Post: boteium
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,467 09-21-2020, 10:02 AM
Last Post: hmuller
  Installing Docker on Pinebook Pro - update 1/18/20 SuperXkoodA 4 7,629 03-24-2020, 03:19 PM
Last Post: chaoskampf
  Swaywm on Pinebook Pro anjanmomi 10 13,983 02-06-2020, 11:47 AM
Last Post: xmixahlx
  Quick Guide to installing Ubuntu Unity on your Pinebook Pro andybleaden@gmail.com 19 23,664 02-03-2020, 11:17 AM
Last Post: MIchael
  Installing Wine i386 on Pinebook Pro wrzomar 0 3,276 01-31-2020, 03:52 PM
Last Post: wrzomar
