Pine as a Pi-hole ... Does that make it a PineHole?
(01-23-2017, 02:37 PM)auger Wrote:
Err:9 http://ppa.launchpad.net/marutter/rdev/ubuntu xenial Release
 404  Not Found
Err:10 http://ppa.launchpad.net/relan/exfat/ubuntu xenial Release
 404  Not Found
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/marutter/rdev/ubuntu xenial Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ppa.launchpad.net/relan/exfat/ubuntu xenial Release' does not have a Release file.
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://repo.ajenti.org/debian main InRelease' doesn't support architecture 'arm64'
N: Skipping acquire of configured file 'ubuntu/binary-arm64/Packages' as repository 'http://repo.ajenti.org/debian main InRelease' doesn't support architecture 'arm64'
W: GPG error: https://cran.cnr.berkeley.edu//bin/linux/debian jessie-cran3/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 06F90DE5381BA480
E: The repository 'https://cran.cnr.berkeley.edu//bin/linux/debian jessie-cran3/ Release' is not signed.
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://dev2day.de/pms jessie InRelease' doesn't support architecture 'arm64'
Looks like a bunch of CRAN and Ajenti repositories that aren't compatible? Would those errors be enough to drop out of the update? Can I have it run to it ignores those?
Thanks!
Those errors are at the operating system level with Ubuntu. We can't bypass those errors as you need to have an updated system in order to install the latest versions of the packages. We don't use any PPA's or other repositories besides the official source repositories so the ones that are generating errors are from another packages installation. You may want to check the PPA and CRAN for updated repository locations.
RE: Pine as a Pi-hole ... Does that make it a PineHole? - by DanSchaper - 01-25-2017, 12:55 PM
  Pine 1 will no longer boot (bricked) dstallmo 0 2,003 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 23,662 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,942 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,771 06-10-2019, 12:07 PM
Last Post: pqueiro
  Pine Board using linux stuck during boot sequence ktaragorn 0 3,454 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 11,076 11-29-2018, 11:46 PM
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,665 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 4,355 05-25-2017, 09:27 AM
  Unable to start Pine Topgun505 16 24,137 11-13-2016, 12:01 AM
Last Post: Gnx
  Problem with Pine honkimonk1 1 4,214 10-11-2016, 09:03 AM
Last Post: Luke
