Pine as a Pi-hole ... Does that make it a PineHole?
Try removing dhcpcd5 after the install.  It has been known to cause DNS lookup issues with piHole on Debain based systems.  piHole will run just fine without it except for the DHCP server.  You will have to remove this every time you upgrade piHole too.
sudo apt remove dhcpcd5
RE: Pine as a Pi-hole ... Does that make it a PineHole? - by chadbhowell - 01-05-2017, 08:21 PM
  Pine 1 will no longer boot (bricked) dstallmo 0 2,010 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 23,697 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,954 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,781 06-10-2019, 12:07 PM
Last Post: pqueiro
  Pine Board using linux stuck during boot sequence ktaragorn 0 3,462 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 11,095 11-29-2018, 11:46 PM
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,674 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 4,363 05-25-2017, 09:27 AM
  Unable to start Pine Topgun505 16 24,199 11-13-2016, 12:01 AM
Last Post: Gnx
  Problem with Pine honkimonk1 1 4,222 10-11-2016, 09:03 AM
Last Post: Luke
