ChromiumOS experience
RE u-boot: The script to patch u-boot on the eMMC is simple enough that it should just work, I don't think it's doing anything that would fail on chromeOS.
If for some reason it does fail I hacked a copy so I could flash to a specified device instead of the detected root; I used this to patch loopback mounted copies of ayufan's images so they're ready to use again if I need them. Just edit DEVID to point at the device you want to flash updated u-boot onto: https://pastebin.com/raw/EeK074XB.
You don't want to be working in crosh, either switch to the debug shell (ctrl+alt+f2) or drop to a proper shell from crosh by running "shell" and then switch to root. I usually just "sudo -i bash" as cronos (default password is "cronos") and away you go.
I tried the ChromeOS build out for a bit last night and it seemed to work well. Netflix video playback seemed significantly smoother compared to Linux, is there better support for hardware accelerated video here vs the Linux builds? My only real gripe with the experience was the touchpad, otherwise the PBP makes a pretty decent chromebook.
ChromiumOS experience - by tsago - 11-07-2019, 07:29 AM
RE: ChromiumOS experience - by tophneal - 11-07-2019, 08:25 AM
RE: ChromiumOS experience - by erchache2000 - 11-08-2019, 04:34 AM
RE: ChromiumOS experience - by tsago - 11-11-2019, 05:14 AM
ChromiumOS experience - by tophneal - 11-08-2019, 05:28 AM
RE: ChromiumOS experience - by danielt - 11-08-2019, 05:49 AM
ChromiumOS experience - by tophneal - 11-08-2019, 05:52 AM
RE: ChromiumOS experience - by Arglebargle - 11-08-2019, 05:52 PM
RE: ChromiumOS experience - by tophneal - 11-08-2019, 10:33 PM
RE: ChromiumOS experience - by Arglebargle - 11-09-2019, 08:17 PM
ChromiumOS experience - by tophneal - 11-09-2019, 09:13 PM
ChromiumOS experience - by tophneal - 11-11-2019, 05:19 AM
RE: ChromiumOS experience - by gabeeg - 11-13-2019, 01:44 PM
RE: ChromiumOS experience - by tophneal - 11-13-2019, 01:47 PM
RE: ChromiumOS experience - by gabeeg - 11-13-2019, 02:15 PM
RE: ChromiumOS experience - by tophneal - 11-21-2019, 01:28 PM
RE: ChromiumOS experience - by richfm - 11-14-2019, 08:57 AM
RE: ChromiumOS experience - by tophneal - 11-26-2019, 08:26 AM
RE: ChromiumOS experience - by fpex73 - 01-15-2020, 03:14 AM
RE: ChromiumOS experience - by Wizzard - 01-15-2020, 03:22 AM
RE: ChromiumOS experience - by fpex73 - 01-15-2020, 03:42 AM
RE: ChromiumOS experience - by tophneal - 01-15-2020, 07:28 AM
