Android 9 from eMMC with ayufan SPI uboot
Hi guys and gals,
I was wondering if anyone managed to boot the already compiled Android 9 image from eMMC. I am using ayufan's SPI flash U-boot and I get strange errors like:
{code}
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
Card did not respond to voltage select!
mmc_init: -95, time 9
{code}
or timeout when trying to read from the mmc.
The SD version works fine, I have not issues.
Furthermore, not even the older Android versions work from eMMC and the SPI U-boot (same errors) but in this case, if I disable the SPI flash, they will boot correctly as opposed to Android 9 which won't boot from regardless.
I'm going to try a linux image on the mmc next, see if I get any different results.
Has anyone encountered this before? please let me know about your experience.
Thanks,
Octavian
PS. I have tried 2 versions of the SPI flash image, the latest and this one https://github.com/ayufan-rock64/linux-u...f9f19116f1
Edit: Yes, Linux works perfectly
Android 9 from eMMC with ayufan SPI uboot - by octavian - 08-17-2019, 11:06 AM
  Android images for RockPro64 BitAnnihilator 1 92 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,805 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,648 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,045 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,483 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,177 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,712 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 24,965 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,103 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 4,038 04-16-2021, 02:03 AM
Last Post: Wizzard
